مفهوم این کد چیه ؟
mohammade79
سلام بچه ها من رو این تیکه موندم اگه بزرگی کنید راهنمایی کنید ممنون میشم :) مفهوم این کد چیه ؟ برای 13 تا دکمه نوشته شده که روی هر کدوم میزنی صدا درمیاره کسی میتونه توضیح بده چیجوری میشه این رو برای 16 تا دکمه نوشت ؟
#Region  Project Attributes
	#ApplicationLabel: B4A Piano Example2
	#VersionCode: 1
	#VersionName: 1.03
	#SupportedOrientations: landscape
#End Region
#Region  Activity Attributes
	#FullScreen: False
	#IncludeTitle: False
#End Region
	 Dim piano_mp(17) As MediaPlayer
	Type Point(Id As Int, prevX As Int, prevY As Int)
	Private list_TOUCHING, list_TOUCHED As List
	Dim G As Gestures
	Dim TouchMap As Map
	Dim pnl_keys(17) As Panel
	Private key1,key2,key3,key4,key5,key6,key7,key8,key9,key10,key11,key12,key13,key14,key15,key16,key17 As Panel
	Activity.LoadLayout("1")
	list_TOUCHING.Initialize
	list_TOUCHED.Initialize
	G.SetOnTouchListener(Activity, "GesturesTouch")
	TouchMap.Initialize
	loadsound 'load sound
	setallpanels 'set panels
Sub loadsound
	For i = 0 To piano_mp.Length -1 'black keys are first because their z order
		piano_mp(i).Initialize
		piano_mp(i).Load(File.DirAssets,"newsound/" & i & ".mp3")
		piano_mp(i).Looping = False
Sub setallpanels
	pnl_keys(0) = key1
	pnl_keys(1) = key2
	pnl_keys(2) = key3
	pnl_keys(3) = key4
	pnl_keys(4) = key5
	pnl_keys(5) = key6
	pnl_keys(6) = key7
	pnl_keys(7) = key8
	pnl_keys(8) = key9
	pnl_keys(9) = key10
	pnl_keys(10) = key11
	pnl_keys(11) = key12
	pnl_keys(12) = key13
	pnl_keys(13) = key14
	pnl_keys(14) = key15
	pnl_keys(15) = key16
	pnl_keys(16) = key17
Sub Activity_Resume
	setallkeystofalse
Sub setallkeystofalse
	list_TOUCHING.Clear
	list_TOUCHING.Clear
	TouchMap.Clear
	resetcolors
Sub resetcolors
	For i = 0 To pnl_keys.Length - 1
		If i < 7 Then
			pnl_keys(i).Color = Colors.Black
			pnl_keys(i).Color = Colors.White
Sub GesturesTouch(View As Object, PointerID As Int, Action As Int, X As Float, Y As Float) As Boolean
	Dim p As Point
	Select Action
		Case G.ACTION_DOWN, G.ACTION_POINTER_DOWN
			p.Id = PointerID
			TouchMap.Put(PointerID, p)
		Case G.ACTION_POINTER_UP
			TouchMap.Remove(PointerID)
		Case G.ACTION_UP
			setallkeystofalse
	End Select
	list_TOUCHING.Clear 'reset touching list
	For i = 0 To TouchMap.Size - 1
		Dim px, py As Int
		p = TouchMap.GetValueAt(i)
		px = G.GetX(p.id)
		py = G.GetY(p.id)
		For Each pnl As Panel In pnl_keys
			If px > pnl.Left And px < pnl.Left + pnl.Width Then
				If py > pnl.Top And py < pnl.Top + pnl.Height Then
					If pnl.Tag > 0 Then
						If list_TOUCHED.IndexOf("1") > -1 Or list_TOUCHED.IndexOf("2") > -1 Or  list_TOUCHED.IndexOf("3") > -1 Or list_TOUCHED.IndexOf("4") > -1 Or list_TOUCHED.IndexOf("5") > -1 Then
							If py < pnl_keys(0).Height Then
								If pnl.Tag = "0" Or pnl.Tag = "0" Then 'right side
								 	If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 0) Then Continue
								else if pnl.Tag = "0" Or pnl.Tag = "0" Then 'left side
									If px < pnl.Left + (pnl_keys(0).Width / 0) Then Continue
								else if pnl.tag = "0" Then
									 If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 0) Or px < pnl.Left + (pnl_keys(0).Width / 0) Then Continue
					list_TOUCHING.Add(pnl.Tag)
					If list_TOUCHED.IndexOf(pnl.Tag) = -1 Then
						list_TOUCHED.Add(pnl.Tag)
						piano_mp(pnl.Tag).Position = 17
						piano_mp(pnl.Tag).Play
	resetcolors
	For i = 0 To list_TOUCHING.Size - 1
		Dim index As String = list_TOUCHING.Get(i)
		If index < 5 Then
			pnl_keys(index).Color = Colors.Blue
			pnl_keys(index).Color = Colors.ARGB(100,0,0,0)
	For i = (list_TOUCHED.Size-1) To 0 Step -1
		If list_TOUCHING.IndexOf(list_TOUCHED.Get(i)) = -1 Then list_TOUCHED.RemoveAt(i)
	Return True
البته اینم بگم که اگه این کد مشخص بشه خیلی کارا با بیسیک ساده میشه مصل ساخت ساز ها و ...
من چیزی که فهمیدم اینه
این قسمت مال لود آهنگ هایه،احتمالا اسم آهنگ ها باید اینجوری باشه
newsound 1
newsound 2
newsound 3
حالا شما بیا بقیه آهنگ هاتو با بزار تو برنامه و اسماشون رو تغییر بده
و تو ساب
Sub setallpanels
بقیه اسماتو وارد کن
نتیجه رو هم اعلام کن
دوست عزیز میدونید مشکل اینجاس که جایی عدد 13 رو نمیبینم ولی این کد فقط برای 13 تا دکمس انگار این کد اصلیشع
نه 13 تا نشون میده هر کاری میکنم سورسو یه تست بزن اگه میتونی این مشکل حل بشه 70 کا پوش دارم برای هر کسی حلش کنه میزنم براش
17 تا دکمه دارم که هر کدومش یه اهنگی روشه اما فقط روی 13 تاش میزنه اهنگو یعنی دکمه 16 رو بزمنی 13 عمل میکنه از 13 ب قبل اوکیه همش
هر کس این مشکلو رفع کرد میتونم براش 70 هزار تا پوش نوتیفیکیشن تبلیغ بزنم
کد شما مشکلی نداره مشکل از تگ پنل ها است که تو دیزاینر تعریف کردید اونجا برای دکمه های 13 به بعد تگ 12 است به خاطر همین فقط یک آهنگ پخش میکنه.
برای این که درست بشه به دیزاینر بروید و تگ هر کلید رو تصحیح کنید مثلا key14 باید تگش 13 باشه key15  تگ 14 باشه و الی آخر.
تست کردم جواب داده موفق باشید
