سلام خسته نباشید توی Appcompat 3.30 برای اندروید با API 19 به پایین کرش دارم :
LogCat connected to: B4A-Bridge: Sony C2105
—------- beginning of /dev/log/main
Error occurred on line: 31 (Main)
java.lang.RuntimeException: Field: _xml not found in: com.myapp.test.main
at anywheresoftware.b4a.shell.Shell$FieldCache.getField(Shell.java:906)
at anywheresoftware.b4a.shell.Shell.setStateBeforeUserSub(Shell.java:487)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:400)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:247)
at java.lang.reflect.Method.invoke(Method.java:511)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:134)
at com.myapp.test.main.afterFirstLayout(main.java:102)
at com.myapp.test.main.access$000(main.java:17)
at com.myapp.test.main$WaitForLayout.run(main.java:80)
at android.os.Handler.handleCallback(Handler.java:725)
at android.os.Handler.dispatchMessage(Handler.java:92)
at android.os.Looper.loop(Looper.java:137)
at android.app.ActivityThread.main(ActivityThread.java:5099)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:803)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:570)
** Activity (main) Resume **
keramat98 82
LogCat connected to: B4A-Bridge: Sony C2105 —------- beginning of /dev/log/main ** Activity (main) Create, isFirst = true ** Error occurred on line: 31 (Main) java.lang.RuntimeException: Field: _xml not found in: com.myapp.test.main at anywheresoftware.b4a.shell.Shell$FieldCache.getField(Shell.java:906) at anywheresoftware.b4a.shell.Shell.setStateBeforeUserSub(Shell.java:487) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:400) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:247) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:511) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:134) at com.myapp.test.main.afterFirstLayout(main.java:102) at com.myapp.test.main.access$000(main.java:17) at com.myapp.test.main$WaitForLayout.run(main.java:80) at android.os.Handler.handleCallback(Handler.java:725) at android.os.Handler.dispatchMessage(Handler.java:92) at android.os.Looper.loop(Looper.java:137) at android.app.ActivityThread.main(ActivityThread.java:5099) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:511) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:803) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:570) at dalvik.system.NativeStart.main(Native Method) ** Activity (main) Resume **ورژن 3.30
Build tools : 23.0.3
Android Support Repository : 40
Google repository : 38
targetSdkVersion : 24
