خیلی انجمن رو زیر رو کردم کد های مختلفی هست که میشه چک کرد که تشخص ارسال sms هست ولی روی کد زیر جواب نمیده
Dim p As PhoneSms
Sub Button1_Click
SendLargeSms("09366928285",EditText1.Text&EditText2.Text)
Sub SendLargeSms(Number As String , Message As String)
Dim r As Reflector
r.Target = r.RunStaticMethod("android.telephony.SmsManager", "getDefault", Null, Null)
Dim parts As Object
parts = r.RunMethod2("divideMessage", Message, "java.lang.String")
r.RunMethod4("sendMultipartTextMessage", _
Array As Object(Number, Null, parts, Null, Null), _
Array As String("java.lang.String", "java.lang.String", _
"java.util.ArrayList", "java.util.ArrayList", "java.util.ArrayList"))
mobah 132
Dim p As PhoneSms Sub Button1_Click SendLargeSms("09366928285",EditText1.Text&EditText2.Text) End Sub Sub SendLargeSms(Number As String , Message As String) Dim r As Reflector r.Target = r.RunStaticMethod("android.telephony.SmsManager", "getDefault", Null, Null) Dim parts As Object parts = r.RunMethod2("divideMessage", Message, "java.lang.String") r.RunMethod4("sendMultipartTextMessage", _ Array As Object(Number, Null, parts, Null, Null), _ Array As String("java.lang.String", "java.lang.String", _ "java.util.ArrayList", "java.util.ArrayList", "java.util.ArrayList")) End Subلینک ارسال
