به پنلش دو تا باتم با کارایی +/- کردن مقدار ادیت تکست گذاشتم
الان وقتی رو باتم کلیک میکنم ؟آخرین id رو مقدار میده
میخوام وقتی رو هر کدوم کلیک می کنم مقدار همون اضافه و کم بشه
#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim megh As Int
Dim Stopint As Int=5%y
Private sql1 As SQL
Private Cur1 As Cursor
Private Label1 As Label
Private Label2 As Label
Private Panel1 As Panel
Private img1 As ImageView
Private img2 As ImageView
Private Button1 As Button
Private Button2 As Button
Private EditText1 As EditText
ScrollView1.Initialize(2000dip)
Activity.Title="Basic4android.org"
Activity.AddView(ScrollView1,0,0,100%x,100%y)
'If File.Exists(File.DirInternal,"1.db")=False Then
File.Copy(File.DirAssets,"1.db",File.DirInternal,"1.db")
'End If
sql1.Initialize(File.DirInternal,"1.db",False)
Cur1=sql1.ExecQuery("SELECT * From data")
For i=0 To Cur1.RowCount-1
Cur1.Position=i
Dim p As Panel
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,Stopint,100%x,100%Y)
Stopint=Stopint+150dip
p.LoadLayout("pnl")
Panel1.Tag=i '''' (range panel ha yek dar miun ghermez va abi mishe)'
If (i Mod 2)=1 Then '''' (range panel ha yek dar miun ghermez va abi mishe)'
Panel1.Color=Colors.Red '''' (range panel ha yek dar miun ghermez va abi mishe)'
Else '''' (range panel ha yek dar miun ghermez va abi mishe)'
Panel1.Color=Colors.Blue '''' (range panel ha yek dar miun ghermez va abi mishe)'
End If '''' (range panel ha yek dar miun ghermez va abi mishe)'
img1.Tag=i
img2.Tag=i
Label1.Text="Name: "&Cur1.GetString("id")&" "&Cur1.GetString("name")
Label2.Text="Text: "&Cur1.GetString("txt")
ScrollView1.Panel.Height=Stopint
EditText1.Text = "amir"
Sub img2_Click
Dim Send As ImageView
Send=Sender
Msgbox2("Set Fav"&Send.Tag,"","","","",Null)
Sub img1_Click
Send=Sender
Msgbox2("Share"&Send.Tag,"","","","",Null)
Sub Button1_Click
If EditText1.Text = "" Then
Button1.Enabled = False
EditText1.text = "deser"
Sub Button2_Click
EditText1.Text=megh
parham01 82
سلام خسته نباشید
از ادیت تکست در اسکرول ویو استفاده کردم
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim megh As Int Dim Stopint As Int=5%y Private sql1 As SQL Private Cur1 As Cursor Private Label1 As Label Private Label2 As Label Private Panel1 As Panel Private ScrollView1 As ScrollView Private img1 As ImageView Private img2 As ImageView Private Button1 As Button Private Button2 As Button Private EditText1 As EditText End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: ScrollView1.Initialize(2000dip) Activity.Title="Basic4android.org" Activity.AddView(ScrollView1,0,0,100%x,100%y) 'If File.Exists(File.DirInternal,"1.db")=False Then File.Copy(File.DirAssets,"1.db",File.DirInternal,"1.db") 'End If sql1.Initialize(File.DirInternal,"1.db",False) Cur1=sql1.ExecQuery("SELECT * From data") For i=0 To Cur1.RowCount-1 Cur1.Position=i Dim p As Panel p.Initialize("p") ScrollView1.Panel.AddView(p,0,Stopint,100%x,100%Y) Stopint=Stopint+150dip p.LoadLayout("pnl") ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Panel1.Tag=i '''' (range panel ha yek dar miun ghermez va abi mishe)' If (i Mod 2)=1 Then '''' (range panel ha yek dar miun ghermez va abi mishe)' Panel1.Color=Colors.Red '''' (range panel ha yek dar miun ghermez va abi mishe)' Else '''' (range panel ha yek dar miun ghermez va abi mishe)' Panel1.Color=Colors.Blue '''' (range panel ha yek dar miun ghermez va abi mishe)' End If '''' (range panel ha yek dar miun ghermez va abi mishe)' ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' img1.Tag=i img2.Tag=i Label1.Text="Name: "&Cur1.GetString("id")&" "&Cur1.GetString("name") Label2.Text="Text: "&Cur1.GetString("txt") ScrollView1.Panel.Height=Stopint Next EditText1.Text = "amir" End Sub Sub img2_Click Dim Send As ImageView Send=Sender Msgbox2("Set Fav"&Send.Tag,"","","","",Null) End Sub Sub img1_Click Dim Send As ImageView Send=Sender Msgbox2("Share"&Send.Tag,"","","","",Null) End Sub Sub Button1_Click If EditText1.Text = "" Then Button1.Enabled = False Else EditText1.text = "deser" End If End Sub Sub Button2_Click EditText1.Text=megh End Subلینک ارسال
