سلام.ببخشید مشکل توی کد من کجاست و میشه راهنمایی کنید
Dim sql1 As SQL
Dim cur1 As Cursor
dim mntm as string = "2"
dim day as string = "3"
dim mnt as string = "43"
File.Copy(File.DirAssets,"my.db",File.DirInternal,"my.db")
sql1.Initialize(File.DirInternal,"my.db",True)
cur1 = sql1.ExecQuery2("INSERT INTO mn(time,day,month)VALUES (?,?,?)",Array As Object (mntm,day,mnt))
ارور java.lang.ClassCastException: java.lang.Object[] cannot be cast to java.lang.String[] میده
ariyan791 10
Dim sql1 As SQL Dim cur1 As Cursor dim mntm as string = "2" dim day as string = "3" dim mnt as string = "43" File.Copy(File.DirAssets,"my.db",File.DirInternal,"my.db") sql1.Initialize(File.DirInternal,"my.db",True) cur1 = sql1.ExecQuery2("INSERT INTO mn(time,day,month)VALUES (?,?,?)",Array As Object (mntm,day,mnt))ارور java.lang.ClassCastException: java.lang.Object[] cannot be cast to java.lang.String[] میده
