// Top-level build file where you can add configuration options common to all sub-projects/modules.
buildscript {
repositories {
jcenter()
dependencies {
classpath 'com.android.tools.build:gradle:2.2.2'
// NOTE: Do not place your application dependencies here; they belong
// in the individual module build.gradle files
allprojects {
repositories {
jcenter()
rayankar 0
Error:The 'java' plugin has been applied, but it is not compatible with the Android plugins.
لطفا اگه کسی بلدهراهنمایی کنه رفته رو اعصاب
buildscript {
repositories {
jcenter()
dependencies {
allprojects {
repositories {
jcenter()
task clean(type: Delete) {
delete rootProject.buildDir
release { minifyEnabled false proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro' } } //} extension dependencies { compile fileTree(include: ['*.jar'], dir: 'libs') compile 'com.android.support:appcompat-v7:23.0.1' }import com.android.build.gradle.AppExtension
apply plugin: 'com.android.application'
apply plugin: 'java'
def extension = android {
compileSdkVersion 23
buildToolsVersion "23"
defaultConfig {
applicationId "ir.apdroid.simplebook"
minSdkVersion 8
targetSdkVersion 23
versionCode 1
versionName "2.0"
release {
minifyEnabled false
extension
dependencies {
