سلام من یک منو شبیه متریال دارم می خوام راست چین کنم باید چی کار کنم؟
لطفا سریع کمک کنید خیلی کارم لنگه
Dim pnlimg As Panel
Dim pnlpass As Panel
pnlpass.Initialize("pnlpass")
pnlpass.Color=Colors.RGB(16,100,107)
pnlimg.Initialize("pnlimg")
pnlimg.SetBackgroundImage(LoadBitmap(File.DirAssets,"icon-bar1.jpg"))
Dim pnlasli As Panel
slide.Initialize("slide")
List1.Initialize("List1")
pnlasli.Initialize("pnlasli")
pnlasli.Color=Colors.RGB(16,150,107)
List1.Color=Colors.White
Dim lbl1 As Label
lbl1=List1.TwoLinesAndBitmap.Label
lbl1.TextColor=Colors.Black
lbl1.TextSize="15"
Dim meghdar As Int = 40%x
slide.BehindOffset = meghdar
pnlasli.AddView(pnlpass,0%x,2%y,70%x,18%y)
pnlasli.AddView(pnlimg,18%x,2%y,32%x,18%y)
pnlasli.AddView(List1,0,22%y,100%x - meghdar,78%y)
slide.Menu.AddView(pnlasli,0,0,100%x - meghdar,100%y)
List1.AddTwoLinesAndBitmap("","",LoadBitmap(File.DirAssets,"lock-menu-final.png"))
List1.AddTwoLinesAndBitmap(" ها","",LoadBitmap(File.DirAssets,"update-menu-final.png"))
List1.AddTwoLinesAndBitmap("هات ","",LoadBitmap(File.DirAssets,"star-menu-final.png"))
List1.AddTwoLinesAndBitmap("","",LoadBitmap(File.DirAssets,"share_menu-final.png"))
List1.AddTwoLinesAndBitmap("ل","",LoadBitmap(File.DirAssets,"exit-menu-final.png"))
List1.AddTwoLinesAndBitmap("خروج","",LoadBitmap(File.DirAssets,"exit-menu-final.png"))
Dim lbl3 As Label
lbl3=List1.SingleLineLayout.Label
lbl3.TextColor=Colors.Black
lbl3.Typeface=Typeface.DEFAULT_BOLD
lbl3.TextSize=17
lbl3.Gravity=Bit.Or( Gravity.CENTER,Gravity.BOTTOM)
Dim img As ImageView
img = List1.TwoLinesAndBitmap.ImageView
img.Left=List1.Width - img.Width-3dip
Dim lbl As Label
lbl=List1.TwoLinesAndBitmap.Label
'lbl.Gravity=Gravity.RIGHT
lbl.left=lbl.left-120dip
lbl.TextColor=Colors.Black
List1.TwoLinesAndBitmap.SecondLabel.Visible=False
List1.TwoLinesAndBitmap.Label.Gravity=Bit.Or(Gravity.CENTER_VERTICAL,Gravity.RIGHT)
List1.TwoLinesAndBitmap.ItemHeight=10%y
List1.TwoLinesAndBitmap.Label.Height=10%y
Dim gra(2) As Int
gra(0) = Colors.RGB(255,255,255)
gra(1) = Colors.RGB(255,255,255)
Dim gradiant1 As GradientDrawable
gradiant1.Initialize("TOP_BOTTOM", gra)
slide.Menu.Background = gradiant1
mostafa.kasiri 115
Dim pnlimg As Panel Dim pnlpass As Panel pnlpass.Initialize("pnlpass") pnlpass.Color=Colors.RGB(16,100,107) pnlimg.Initialize("pnlimg") pnlimg.SetBackgroundImage(LoadBitmap(File.DirAssets,"icon-bar1.jpg")) Dim pnlasli As Panel slide.Initialize("slide") List1.Initialize("List1") pnlasli.Initialize("pnlasli") pnlasli.Color=Colors.RGB(16,150,107) List1.Color=Colors.White Dim lbl1 As Label lbl1=List1.TwoLinesAndBitmap.Label lbl1.TextColor=Colors.Black lbl1.TextSize="15" Dim meghdar As Int = 40%x slide.BehindOffset = meghdar pnlasli.AddView(pnlpass,0%x,2%y,70%x,18%y) pnlasli.AddView(pnlimg,18%x,2%y,32%x,18%y) pnlasli.AddView(List1,0,22%y,100%x - meghdar,78%y) slide.Menu.AddView(pnlasli,0,0,100%x - meghdar,100%y) List1.AddTwoLinesAndBitmap("","",LoadBitmap(File.DirAssets,"lock-menu-final.png")) List1.AddTwoLinesAndBitmap(" ها","",LoadBitmap(File.DirAssets,"update-menu-final.png")) List1.AddTwoLinesAndBitmap("هات ","",LoadBitmap(File.DirAssets,"star-menu-final.png")) List1.AddTwoLinesAndBitmap("","",LoadBitmap(File.DirAssets,"share_menu-final.png")) List1.AddTwoLinesAndBitmap("ل","",LoadBitmap(File.DirAssets,"exit-menu-final.png")) List1.AddTwoLinesAndBitmap("خروج","",LoadBitmap(File.DirAssets,"exit-menu-final.png")) Dim lbl3 As Label lbl3=List1.SingleLineLayout.Label lbl3.TextColor=Colors.Black lbl3.Typeface=Typeface.DEFAULT_BOLD lbl3.TextSize=17 lbl3.Gravity=Bit.Or( Gravity.CENTER,Gravity.BOTTOM) Dim img As ImageView img = List1.TwoLinesAndBitmap.ImageView img.Left=List1.Width - img.Width-3dip Dim lbl As Label lbl=List1.TwoLinesAndBitmap.Label 'lbl.Gravity=Gravity.RIGHT lbl.left=lbl.left-120dip lbl.TextColor=Colors.Black List1.TwoLinesAndBitmap.SecondLabel.Visible=False List1.TwoLinesAndBitmap.Label.Gravity=Bit.Or(Gravity.CENTER_VERTICAL,Gravity.RIGHT) List1.TwoLinesAndBitmap.ItemHeight=10%y List1.TwoLinesAndBitmap.Label.Height=10%y Dim gra(2) As Int gra(0) = Colors.RGB(255,255,255) gra(1) = Colors.RGB(255,255,255) Dim gradiant1 As GradientDrawable gradiant1.Initialize("TOP_BOTTOM", gra) slide.Menu.Background = gradiant1
