سلام دوستان من در استفاده از اپکامپت در بیسیک با ارور زیر مواجه میشم لطفا کمکم کند.
** Service (starter) Create **
** Service (starter) Start **
Error occurred on line: 53 (Main)
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:166)
at anywheresoftware.b4a.objects.ActivityWrapper.LoadLayout(ActivityWrapper.java:209)
at java.lang.reflect.Method.invoke(Method.java:515)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:708)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:340)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:247)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:134)
at b4a.example.TastyToast.main.afterFirstLayout(main.java:102)
at b4a.example.TastyToast.main.access$000(main.java:17)
at b4a.example.TastyToast.main$WaitForLayout.run(main.java:80)
at android.os.Handler.handleCallback(Handler.java:733)
at android.os.Looper.loop(Looper.java:136)
at android.app.ActivityThread.main(ActivityThread.java:5001)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601)
Caused by: java.lang.reflect.InvocationTargetException
at anywheresoftware.b4a.objects.CustomViewWrapper.AfterDesignerScript(CustomViewWrapper.java:64)
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:158)
... 21 more
Caused by: android.content.res.Resources$NotFoundException: File res/drawable-v19/abc_ic_ab_back_material.xml from drawable resource ID #0x7f020013
at android.content.res.Resources.loadDrawable(Resources.java:2096)
at android.content.res.Resources.getDrawable(Resources.java:700)
at android.support.v4.content.ContextCompat.getDrawable(ContextCompat.java:354)
at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:193)
at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:181)
at android.support.v7.widget.TintTypedArray.getDrawable(TintTypedArray.java:67)
at android.support.v7.widget.Toolbar.<init>(Toolbar.java:298)
at android.support.v7.widget.Toolbar.<init>(Toolbar.java:229)
at android.support.v7.widget.Toolbar.<init>(Toolbar.java:225)
at de.amberhome.objects.appcompat.ACToolbarLightWrapper.innerInitialize(ACToolbarLightWrapper.java:25)
at anywheresoftware.b4a.objects.ViewWrapper.Initialize(ViewWrapper.java:65)
at de.amberhome.objects.appcompat.ACToolBarWrapper.Initialize(ACToolBarWrapper.java:62)
at de.amberhome.objects.appcompat.ACToolBarWrapper._initialize(ACToolBarWrapper.java:141)
... 25 more
Caused by: org.xmlpull.v1.XmlPullParserException: Binary XML file line #17: invalid drawable tag vector
at android.graphics.drawable.Drawable.createFromXmlInner(Drawable.java:933)
at android.graphics.drawable.Drawable.createFromXml(Drawable.java:877)
at android.content.res.Resources.loadDrawable(Resources.java:2092)
... 37 more
** Activity (main) Resume **
hem20xZ 0
