ocess_Globals
Dim megdar As Int
Private Panel1 As Panel
Private Label1 As Label
Dim cur1 As Cursor
Dim sql1 As SQL
Dim stop As Int = 3%y
Activity.LoadLayout("list")
ScrollView1.Color = Colors.Transparent
ScrollView1.Panel.Color = Colors.Transparent
If File.Exists(File.DirInternal,"a1.db")=False Then
File.Copy(File.DirAssets,"a1.db",File.DirInternal,"a1.db")
sql1.Initialize(File.DirInternal,"a1.db",False)
cur1=sql1.ExecQuery("SELECT * From tab1")
For i = 0 To cur1.RowCount-1
cur1.Position = i
Dim p As Panel
p.Initialize("p")
stop = stop + 35%y
p.LoadLayout("panlscro")
Label1.Text = cur1.GetString("titr")
ScrollView1.Panel.Height = stop
Sub Activity_Resume
می خواستم بپرسم چه کار کنم که اگه روی هر آیتمی کلیک شد دستور زیر انجام شود.
megdar =
'می خواهم روی هر آیتمی کلیک شد مقدار این متغیر برابر با همان شود (مثلا اگه روی آیتم 1 کلیک شد مقدار متغیر 1 شود اگه روی 2 مقدارش 2 شود)
StartActivity("matn")
Activity.Finish
ebraeim 8
با این کدها یک لسیت با اسکرول ویو ساختم
ocess_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim megdar As Int End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private ScrollView1 As ScrollView Private Panel1 As Panel Private Label1 As Label Dim cur1 As Cursor Dim sql1 As SQL Dim stop As Int = 3%y End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("list") ScrollView1.Color = Colors.Transparent ScrollView1.Panel.Color = Colors.Transparent If File.Exists(File.DirInternal,"a1.db")=False Then File.Copy(File.DirAssets,"a1.db",File.DirInternal,"a1.db") End If sql1.Initialize(File.DirInternal,"a1.db",False) cur1=sql1.ExecQuery("SELECT * From tab1") For i = 0 To cur1.RowCount-1 cur1.Position = i Dim p As Panel p.Initialize("p") ScrollView1.Panel.AddView(p,0,stop,100%x,100%y) stop = stop + 35%y p.LoadLayout("panlscro") Label1.Text = cur1.GetString("titr") ScrollView1.Panel.Height = stop Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subمی خواستم بپرسم چه کار کنم که اگه روی هر آیتمی کلیک شد دستور زیر انجام شود.
megdar = 'می خواهم روی هر آیتمی کلیک شد مقدار این متغیر برابر با همان شود (مثلا اگه روی آیتم 1 کلیک شد مقدار متغیر 1 شود اگه روی 2 مقدارش 2 شود) StartActivity("matn") Activity.Finishلینک ارسال
