سلام من با استفاده از کد زیر برنامه رو کامپایل کردم اما نمیدونم چرا فقط عکس آخر دانلود میشه.
Dim hg As HttpJob
Private Panel1 As Panel
Private Label1 As Label
Dim p As Panel
Dim ok As Int = 3%y
hg.Initialize("hg",Me)
Dim milad() As String=Regex.Split("<br>", Main.mil)
For i = 0 To milad.Length-1
Dim joda() As String=Regex.Split("#",milad(i))
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,ok,100%x,100%y)
ok = ok + 52%y
p.LoadLayout("Layout")
p.Tag=i
Label1.Text=joda(1)
hg.Download(joda(1))
ScrollView1.Panel.Height= ok
Sub jobdone ( job As HttpJob)
If job.Success = True Then
If job.JobName = "hg" Then
ImageView1.Bitmap = job.GetBitmap
میلاد حائری 180
Sub Globals Dim hg As HttpJob Private ImageView1 As ImageView Private Panel1 As Panel Private ScrollView1 As ScrollView Private Label1 As Label Dim p As Panel Dim ok As Int = 3%y End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("Layout1") hg.Initialize("hg",Me) Dim milad() As String=Regex.Split("<br>", Main.mil) For i = 0 To milad.Length-1 Dim joda() As String=Regex.Split("#",milad(i)) p.Initialize("p") ScrollView1.Panel.AddView(p,0,ok,100%x,100%y) ok = ok + 52%y p.LoadLayout("Layout") p.Tag=i Label1.Text=joda(1) hg.Download(joda(1)) ScrollView1.Panel.Height= ok Next End Sub Sub jobdone ( job As HttpJob) If job.Success = True Then If job.JobName = "hg" Then ImageView1.Bitmap = job.GetBitmap End If End If End Subاینم عکسش
