امین پوراباذری 1,045 ارسال شده در 30 مرداد، 2017 اشتراک گذاری ارسال شده در 30 مرداد، 2017 نسخه ی بیسیک فور اندورید ورژن 7.01 همراه با کرک ویژگی های اضافه شده به این نسخه Resumable subs - Wait For / Sleep: B4X - Rapid Application Development tools for Android, iOS and desktop applications[B4X] SQL with Wait For[B4X] OkHttpUtils2 with Wait For Async dialogs: Android Tutorial - DoEvents deprecated and async dialogs (msgbox) | B4X Community - Android, iOS, desktop, server and IoT programming tools Variables and subs renaming based on the Find All References feature: Quick search supports replacing including replacing in all modules. Icon picker - Filter field supports filtering by hex code. Starter service better handles cases where the process is started by multiple intents. CSBuilder.Image adds an underscore instead of space to fix an issue with multiline strings. Application_Error - Fixed a compatibility issue with Android 2.2. PhoneCalls - READ_CALL_LOG permission added. This is a new requirement. Sender is set when raising events with CallSub or CallSubDelayed from classes. Debugger improvements related to deployments of large projects. It is recommended to upgrade B4A-Bridge to v2.31: B4A-Bridge - Android Apps on Google Play DoEvents is deprecated. A warning will appear when using it (see the async dialogs tutorial). Note that it is still supported, exactly as before. SQL library updated to make it simpler to use with Wait For. مهمترین ویژگی اضافه شده طبق گفته ی ارل از نسخه ی 2 بیسیک تا به امروز ویژگی Resumable subs - Wait For لینک مربوطه رو باز کنید نحوه ی استفاده از قابلیت رو متوجه خواهید شد.B4X - Rapid Application Development tools for Android, iOS and desktop applications دقت کنید برای استفاده از بیسیک 7 باید حتما از جاوا 8 استفاده کنید. B4A 7.01 Retail.zip لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
