MdSwitchButton
nw1992
یک Switch Button زیبا، کم حجم با قابلیت سفارشی سازی سازگار با اندروید>11
ویژگی ها
– بدون نیاز به کتابخانه های اضافی
– بدون نیاز به فایل های xml
– قابلیت درگ کردن برای switch
این کتابخونه رو از این لینک ریپ کردم.
MdSwitchButton
Author:
 Milad Mohammadi
Version: 1.0
  • MdSwitchButton
    Fields:
    • CheckedChange(Checked As Boolean)
    Methods:
    • BringToFront
    • DesignerCreateView (base As PanelWrapper, lw As LabelWrapper, props AsMap)
    • Initialize (EventName As String)
    • Invalidate
    • Invalidate2 (Rect As Rect)
    • Invalidate3 (Left As Int, Top As Int, Right As Int, Bottom As Int)
    • IsInitialized As Boolean
    • RemoveView
    • RequestFocus As Boolean
    • SendToBack
    • SetLayout (Left As Int, Top As Int, Right As Int, Bottom As Int)
    • Toggle
    Properties:
    • Background As Int [write only]
    • BorderWidth As Float [write only]
    • ButtonColor As Int [write only]
    • Check As Boolean
    • CheckColor As Int [write only]
    • CheckLineColor As Int [write only]
    • CheckLineWidth As Int [write only]
    • EffectDuration As Int [write only]
    • EnableEffect As Boolean [write only]
    • Height As Int
    • Left As Int
    • Parent As Int
    • ShadowColor As Int [write only]
    • ShadowEffect As Boolean [write only]
    • ShadowOffset As Float [write only]
    • ShadowRadius As Float [write only]
    • ShowIndicator As Boolean [write only]
    • Tag As Object
    • Top As Int
    • UnCheckCircleColor As Int [write only]
    • UnCheckCircleRadius As Float [write only]
    • UnCheckCircleWidth As Float [write only]
    • UnCheckColor As Int [write only]
    • Visible As Boolean
    • Width As Int
دانلود پلاگین
دانلود مثال
