من با این کد ها خیلی شیک و مجلسی تب هاست متریال رو راه اندازی می کنم
#Region Project Attributes
#ApplicationLabel: B4A Example
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
#AdditionalRes: ..\resource
#Extends: android.support.v7.app.AppCompatActivity
Sub Process_Globals
Private PC As AHPageContainer
Private ToolBar1 As ACToolBarLight
Private TabLayout1 As DSTabLayout
Private VP As AHViewPager
PC.Initialize
For i = 0 To 2
Dim p As Panel
p.Initialize("")
p.Color = Colors.RGB( Rnd(0 ,256 ) , Rnd(0 , 256) , Rnd(0 , 256 ) )
PC.AddPage(p , "Tab Host" )
VP.PageContainer = PC
Dim ac As AppCompat
TabLayout1.Color = ac.GetThemeAttribute("colorPrimary")
TabLayout1.SetViewPager(VP)
Dim xml As XmlLayoutBuilder
TabLayout1.SetTabIcon(0 , xml.GetDrawable("ic_alarm_white_24dp"))
TabLayout1.SetTabIcon(1 , xml.GetDrawable("ic_favorite_white_24dp"))
TabLayout1.SetTabIcon(2 , xml.GetDrawable("ic_settings_white_24dp"))
' answercenter.ir
Sub Activity_Resume
چطوری میتونم به هر تب یک لایوت جدا بدم؟
اینکار در تب هاست معمولی به راحتی انجام میشه ... ولی در متریال نمی دونم چیکار کنم؟
مجتبی خیری 21
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region #AdditionalRes: ..\resource #Extends: android.support.v7.app.AppCompatActivity Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private PC As AHPageContainer Private ToolBar1 As ACToolBarLight Private TabLayout1 As DSTabLayout Private VP As AHViewPager End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("Layout1") PC.Initialize For i = 0 To 2 Dim p As Panel p.Initialize("") p.Color = Colors.RGB( Rnd(0 ,256 ) , Rnd(0 , 256) , Rnd(0 , 256 ) ) PC.AddPage(p , "Tab Host" ) ' --------------------------------- Next VP.PageContainer = PC Dim ac As AppCompat TabLayout1.Color = ac.GetThemeAttribute("colorPrimary") TabLayout1.SetViewPager(VP) Dim xml As XmlLayoutBuilder TabLayout1.SetTabIcon(0 , xml.GetDrawable("ic_alarm_white_24dp")) TabLayout1.SetTabIcon(1 , xml.GetDrawable("ic_favorite_white_24dp")) TabLayout1.SetTabIcon(2 , xml.GetDrawable("ic_settings_white_24dp")) ' answercenter.ir End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subچطوری میتونم به هر تب یک لایوت جدا بدم؟
