از کتابخانه پیکاسو داخل برنامم استفاده کردم ولی وقتی ران میگیرم ارور میده..مشکلش چیه؟
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.IllegalArgumentException: already added: Luk/co/martinpearman/b4a/squareup/picasso/RequestBuilder;
at com.android.dx.dex.file.ClassDefsSection.add(ClassDefsSection.java:122)
at com.android.dx.dex.file.DexFile.add(DexFile.java:161)
at com.android.dx.command.dexer.Main.processClass(Main.java:615)
at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570)
at com.android.dx.command.dexer.Main.access$2(Main.java:546)
at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514)
at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
at com.android.dx.command.dexer.Main.processOne(Main.java:537)
at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236)
at com.android.dx.command.dexer.Main.run(Main.java:206)
at com.android.dx.command.dexer.Main.main(Main.java:179)
at com.android.dx.command.Main.main(Main.java:103)
1 error; aborting
H4N9_0V3R 7
UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.IllegalArgumentException: already added: Luk/co/martinpearman/b4a/squareup/picasso/RequestBuilder; at com.android.dx.dex.file.ClassDefsSection.add(ClassDefsSection.java:122) at com.android.dx.dex.file.DexFile.add(DexFile.java:161) at com.android.dx.command.dexer.Main.processClass(Main.java:615) at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570) at com.android.dx.command.dexer.Main.access$2(Main.java:546) at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514) at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284) at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166) at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144) at com.android.dx.command.dexer.Main.processOne(Main.java:537) at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236) at com.android.dx.command.dexer.Main.run(Main.java:206) at com.android.dx.command.dexer.Main.main(Main.java:179) at com.android.dx.command.Main.main(Main.java:103) 1 error; abortingلینک ارسال
