دوستان ممنون میشم اگه کسی مستونه و لایسنس داره این درخواست من رو تو سایت اصلی بذاره چون من خودم لایسنس ندارم درخواستم حذف میشه
hello friends
I'm having trouble with the pdf view and this makes fail my project
Thank you for helping me
I need to display the pdf in my project and use the library and the following method, which is has problem to use
1. b4aPDFViewer (1.12): The problem is that it is not compatible with Android 6 and you are enabled to use and it become force close
2. The PDFViewer (1.5) library: The application closes the program when a PDF is displayed.when activity close the application closes the program.
3- The PdfViewer-Radaee library: This library is from an Android studio library with the same name that isnt free and write the pdf Watermark on pages.
4. Using an Instantiate: Because i do not want user copy the PDF this way isent usable
i requeste help me
in following there are two links that removed download links
please someone have them uploaded in this to i can downloaded them
m007moh 181
hello friends
i requeste help me
B4X - Rapid Application Development tools for Android, iOS and desktop applications
PDF-View - Show PDF files in your own app | B4X Community - Android, iOS, desktop, server and IoT programming tools
