سلام من همه کار های لازمه رو انجام دادم ولی موقعه اجرا این ارور رو میده
B4A version: 6.30
Parsing code. (0.00s)
Compiling code. (0.04s)
Compiling layouts code. (0.01s)
Organizing libraries. (0.00s)
Generating R file. Error
c:\program files\android\sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:75: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton'.
c:\program files\android\sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:79: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.CloseMode'.
c:\program files\android\sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:83: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.Overflow'.
c:\program files\android\sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:25: error: Error retrieving parent for item: No resource found that matches the given name 'anc:\program
files\android\sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:191: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
user375 2
B4A version: 6.30
کسی میدونه مشکل چیه؟
