java.lang.IllegalArgumentException: You need to use a Theme.AppCompat theme (or descendant) with the design library.
at android.support.design.widget.ThemeUtils.checkAppCompatTheme(ThemeUtils.java:36)
at android.support.design.widget.Snackbar.<init>(Snackbar.java:187)
at android.support.design.widget.Snackbar.make(Snackbar.java:217)
at de.amberhome.objects.SnackbarWrapper.Initialize(SnackbarWrapper.java:49)
at b4a.example.main._i_click(main.java:616)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:708)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:337)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:247)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:134)
at anywheresoftware.b4a.BA.raiseEvent(BA.java:153)
at b4a.example.main$B4AMenuItemsClickListener.onMenuItemClick(main.java:191)
at android.support.v7.view.menu.MenuItemImpl.invoke(MenuItemImpl.java:148)
at android.support.v7.view.menu.MenuBuilder.performItemAction(MenuBuilder.java:957)
at android.support.v7.view.menu.MenuBuilder.performItemAction(MenuBuilder.java:947)
at android.support.v7.view.menu.MenuPopup.onItemClick(MenuPopup.java:126)
at android.widget.AdapterView.performItemClick(AdapterView.java:314)
at android.widget.AbsListView.performItemClick(AbsListView.java:1155)
at android.widget.AbsListView$PerformClick.run(AbsListView.java:3068)
at android.widget.AbsListView$3.run(AbsListView.java:3933)
at android.os.Handler.handleCallback(Handler.java:743)
at android.os.Looper.loop(Looper.java:150)
at android.app.ActivityThread.main(ActivityThread.java:5546)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:792)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:682)
reza644 435
سلام وقتی میخوام اسنک بار اجرا شه ارور میده
نسخه اپ کامپ:3.2
نسخه دیزاین ساپورت:2
ارور مربوطه:
کد مربوطه
s1.Initialize("s1",Activity,"تست.",s1.DURATION_SHORT) s1.Showلینک ارسال
