*** Service (starter) Create ***
java.lang.RuntimeException: Unable to start activity ComponentInfo{ir.apk_ahangzang/ir.apk_ahangzang.home}: java.lang.ClassCastException: android.support.v7.internal.widget.ContentFrameLayout cannot be cast to android.support.v7.internal.widget.NativeActionModeAwareLayout
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2379)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2442)
at android.app.ActivityThread.access$800(ActivityThread.java:156)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1351)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:211)
at android.app.ActivityThread.main(ActivityThread.java:5371)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:945)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:740)
Caused by: java.lang.ClassCastException: android.support.v7.internal.widget.ContentFrameLayout cannot be cast to android.support.v7.internal.widget.NativeActionModeAwareLayout
at android.support.v7.app.ActionBarActivityDelegateHC.onSubDecorInstalled(ActionBarActivityDelegateHC.java:41)
at android.support.v7.app.ActionBarActivityDelegateBase.ensureSubDecor(ActionBarActivityDelegateBase.java:384)
at android.support.v7.app.ActionBarActivityDelegateBase.setContentView(ActionBarActivityDelegateBase.java:228)
at android.support.v7.app.ActionBarActivity.setContentView(ActionBarActivity.java:107)
at ir.apk_ahangzang.home.onCreate(home.java:59)
at android.app.Activity.performCreate(Activity.java:5990)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1106)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2332)
... 10 more
** Service (time) Start **
Siaic 88
سلام ارور زیر ینی چی؟
*** Service (starter) Create *** java.lang.RuntimeException: Unable to start activity ComponentInfo{ir.apk_ahangzang/ir.apk_ahangzang.home}: java.lang.ClassCastException: android.support.v7.internal.widget.ContentFrameLayout cannot be cast to android.support.v7.internal.widget.NativeActionModeAwareLayout at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2379) at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2442) at android.app.ActivityThread.access$800(ActivityThread.java:156) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1351) at android.os.Handler.dispatchMessage(Handler.java:102) at android.os.Looper.loop(Looper.java:211) at android.app.ActivityThread.main(ActivityThread.java:5371) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:945) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:740) Caused by: java.lang.ClassCastException: android.support.v7.internal.widget.ContentFrameLayout cannot be cast to android.support.v7.internal.widget.NativeActionModeAwareLayout at android.support.v7.app.ActionBarActivityDelegateHC.onSubDecorInstalled(ActionBarActivityDelegateHC.java:41) at android.support.v7.app.ActionBarActivityDelegateBase.ensureSubDecor(ActionBarActivityDelegateBase.java:384) at android.support.v7.app.ActionBarActivityDelegateBase.setContentView(ActionBarActivityDelegateBase.java:228) at android.support.v7.app.ActionBarActivity.setContentView(ActionBarActivity.java:107) at ir.apk_ahangzang.home.onCreate(home.java:59) at android.app.Activity.performCreate(Activity.java:5990) at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1106) at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2332) ... 10 more ** Service (time) Start **لینک ارسال
