ahmad36
سلام، من در اجرای پروژه با ارور زیر روبرو میشم
B4A Version: 7.30 Parsing code. (0.00s) Compiling code (0.46s) Compiling layouts code (0.05s) Organizing libraries (0.00s) Generating R file. (0.08s) Compiling debugger engine code (1.88s) Compiling generated Java code. Error javac 1.8 javac: file not found: gen b4alexampleARjava Usage: javac Koptions> <source files use help for a list of possible options This error usually happens when you save the project under a restricted folder such as Program Files
