سلام من ی متن از دیتابیس با کتابخوانه فراخوانی و تکس سیتینگ فراخوانی کردم ولی وقتی کامپایل میکنم بین خط ها فاصله ی بسیار زیادی میوفته از رفلکتور هم برای تنطیم فاصله بین خطوط استفاده کردم ولی نشد
لطفا کمکم کنید
کد ها :
Dim cur As Cursor
Dim fara As Farakhani
Dim ts As TextSetting
Activity.LoadLayout("scrol")
Dim lbl As Label
lbl.Initialize("")
fara.FarakhaniMatn("football1.db",sql,cur,"select * from tfootball where id=","1",lbl,"text")
ts.Initialize
ScrollView1.Panel.AddView(lbl,0,0,100%X,100%Y)
ts.LongText(lbl,lbl.Text,20,ScrollView1,30)
lbl.TextColor=Colors.Black
Sub Activity_Resume
Sub setlinespace (lbl As Label,meghdar As Float)
Dim reflector As Reflector
reflector.Target=lbl
reflector.RunMethod3("setlinespacing",1,"java.lang.float",meghdar,"java.lang.float")
soroush.p.p 2
لطفا کمکم کنید
کد ها :
Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim cur As Cursor Dim fara As Farakhani Dim ts As TextSetting Private ScrollView1 As ScrollView End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("scrol") Dim lbl As Label lbl.Initialize("") fara.FarakhaniMatn("football1.db",sql,cur,"select * from tfootball where id=","1",lbl,"text") ts.Initialize ScrollView1.Panel.AddView(lbl,0,0,100%X,100%Y) ts.LongText(lbl,lbl.Text,20,ScrollView1,30) lbl.TextColor=Colors.Black End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub setlinespace (lbl As Label,meghdar As Float) Dim reflector As Reflector reflector.Target=lbl reflector.RunMethod3("setlinespacing",1,"java.lang.float",meghdar,"java.lang.float") End Sub
