با سلام خدمت دوستان برنامه من هنگام restore خطا میگیره مبتدی هستم . مشکل از کجاست
#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
'Database
Dim SQL1 As SQL
Dim DBFileDir As String : DBFileDir = File.DirDefaultExternal
Dim DBFileName As String : DBFileName = "mydb.s3db"
Dim DBFileBak As String : DBFileBak = "mydb.bak"
Activity.LoadLayout("mm")
Sub Activity_Resume
' File.Copy(File.DirAssets,"mm.db",File.DirInternal,MPD.PersianShortDate&".db")
Sub Button1_Click
SQL1.Close
File.Copy(File.DirAssets, "mm.db", File.DirInternal, "mm.db")
SQL1.Initialize(File.DirRootExternal, "mm.db", True)
Msgbox("Database has been Backed Up", "")
Sub Button2_Click
SQL1.Close
File.Copy(File.DirAssets, "mm.db", File.DirAssets, "mm.db")
Msgbox("Database has been Restored", "")
mohsen1230 0
#VersionCode: 1
#VersionName:
#End Region
#FullScreen: False
#IncludeTitle: True
#End Region
'Database
Dim SQL1 As SQL
Sub Activity_Resume
Sub Button1_Click
SQL1.Close
Sub Button2_Click
SQL1.Close
