D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "imageAspectRatioAdjust" has already been defined
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "imageAspectRatio" has already been defined
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "circleCrop" has already been defined
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "buttonSize" has already been defined
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "colorScheme" has already been defined
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "scopeUris" has already been defined
موقع کامپایل این خطا میاد. نمیدونم از چیه. یک کتابخونه از یک سایتی گرفتم ریختم تو لایبرری ها و بعد سورس خطا داد کتابخانه رو ب حالت قبل آوردم خطای دیگه داد . کلا یجور شد ک از نو نصب کردم همه چیز رو اما بعدش این خطا اومد.
hocein 40
D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "imageAspectRatioAdjust" has already been defined D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "imageAspectRatio" has already been defined D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res3\res\values\values.xml:3: error: Attribute "circleCrop" has already been defined D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "buttonSize" has already been defined D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "colorScheme" has already been defined D:\Project\Ordoyar Sos Up5\Objects\bin\extra\res2\res\values\values.xml:21: error: Attribute "scopeUris" has already been defined
