سلام یه مشکل دارم تو کدنویسی میخوام وقتی منو اسلاید باز میشه مثلا رویدرباره ی ما کلیک کنم وارد یه اکتیویتی جدید بشم نمیدونم چکار کنم این از کد من
[size=4]Version=2.71
IconFile=
NumberOfModules=0
Package=b4a.example
DoNotOverwriteManifest=False
ManifestCode='This code will be applied to the manifest file during compilation.~\n~'You do not need to modify it in most cases.~\n~'See this link for for more information: http://www.basic4ppc.com/forum/showthread.php?p=78136~\n~AddManifestText(~\n~<uses-sdk android:minSdkVersion="4" android:targetSdkVersion="14"/>~\n~<supports-screens android:largeScreens="true" ~\n~ android:normalScreens="true" ~\n~ android:smallScreens="true" ~\n~ android:anyDensity="true"/>)~\n~SetApplicationAttribute(android:icon, "@drawable/icon")~\n~SetApplicationAttribute(android:label, "$LABEL$")~\n~'End of default text.~\n~
UserTypesHint=
NumberOfFiles=1
File1=main.bal
NumberOfLibraries=2
Library1=core
Library2=sidemenubar
@EndOfDesignText@
#Region Project Attributes
#ApplicationLabel: B4A Example
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Sub Process_Globals
Dim menu As SideMenuBar
Dim a As Typeface
Dim b As Bitmap
Dim i As Int = 0
Activity.LoadLayout("main")
b.Initialize(File.DirAssets,"logo.png")
a = Typeface.LoadFromAssets("dastnevis.otf")
menu.Initialize("gh",Me,50%x,True,a,Colors.RGB(184,163,0),b,1,Colors.Black)
menu.add_item("صفحه اصلی","",LoadBitmap(File.DirAssets,"Home.png"),1)
menu.add_item("درباره ما","",LoadBitmap(File.DirAssets,"person-icon.png"),2)
menu.add_item("ارتباط با ما","",LoadBitmap(File.DirAssets,"telephone-icon.png"),3)
menu.add_item("خروج","",LoadBitmap(File.DirAssets,"exit.png"),4)
menu.make(Activity)
Sub Activity_Resume
Sub b_show_Click
If i = 0 Then
menu.show
menu.hide
Sub gh_Opened()
i = 1
Sub gh_Closed()
i = 0
Sub gh_Click(Item As Object)
ToastMessageShow("Item clicked: " & Item, False)
[/size]
بعدش یه سوال دیگه آیا میشه بک گراند خود من و اسلاید هم عوض کرد?
محمدی 95
