مشکل در اسلاید منو
محمدی
سلام یه مشکل دارم تو کدنویسی میخوام وقتی منو اسلاید باز میشه مثلا رویدرباره ی ما کلیک کنم وارد یه اکتیویتی جدید بشم نمیدونم چکار کنم این از کد من
[size=4]Version=2.71
IconFile=
NumberOfModules=0
Package=b4a.example
DoNotOverwriteManifest=False
ManifestCode='This code will be applied to the manifest file during  compilation.~\n~'You do not need to modify it in most cases.~\n~'See  this link for for more information:  http://www.basic4ppc.com/forum/showthread.php?p=78136~\n~AddManifestText(~\n~<uses-sdk  android:minSdkVersion="4"  android:targetSdkVersion="14"/>~\n~<supports-screens  android:largeScreens="true" ~\n~    android:normalScreens="true" ~\n~     android:smallScreens="true" ~\n~     android:anyDensity="true"/>)~\n~SetApplicationAttribute(android:icon,  "@drawable/icon")~\n~SetApplicationAttribute(android:label,  "$LABEL$")~\n~'End of default text.~\n~
UserTypesHint=
NumberOfFiles=1
File1=main.bal
NumberOfLibraries=2
Library1=core
Library2=sidemenubar
@EndOfDesignText@
#Region  Project Attributes
   #ApplicationLabel: B4A Example
   #VersionCode: 1
   #VersionName:
#End Region
#Region  Activity Attributes
   #FullScreen: False
   #IncludeTitle: True
#End Region
Sub Process_Globals
   Dim menu As SideMenuBar
   Dim a As Typeface
   Dim b As Bitmap
   Dim i As Int = 0
   Activity.LoadLayout("main")
   b.Initialize(File.DirAssets,"logo.png")
   a = Typeface.LoadFromAssets("dastnevis.otf")
   menu.Initialize("gh",Me,50%x,True,a,Colors.RGB(184,163,0),b,1,Colors.Black)
   menu.add_item("صفحه اصلی","",LoadBitmap(File.DirAssets,"Home.png"),1)
   menu.add_item("درباره ما","",LoadBitmap(File.DirAssets,"person-icon.png"),2)
   menu.add_item("ارتباط با ما","",LoadBitmap(File.DirAssets,"telephone-icon.png"),3)
   menu.add_item("خروج","",LoadBitmap(File.DirAssets,"exit.png"),4)
   menu.make(Activity)
Sub Activity_Resume
Sub b_show_Click
   If i = 0 Then
       menu.show
       menu.hide
Sub gh_Opened()
   i = 1
Sub gh_Closed()
   i = 0
Sub gh_Click(Item As Object)
   ToastMessageShow("Item clicked: " & Item, False)
[/size]
بعدش یه سوال دیگه آیا میشه بک گراند خود من و اسلاید هم عوض کرد?
هر دو تا رو باهم زیپ کردم میتونید دان کنید.
فک نکنم بشه واسه پس زمینه عکس گذاشت ولی اگه شد حتما کدشو میزارم*hoho*
http://s6.picofile.com/file/8182024900/SlidingPanels.zip.html
   Dim slidingmenu1 As SlidingMenu
   Dim listview1 As ListView
   Dim font As Typeface
   Private Button1 As Button
   Activity.LoadLayout("splash")
   font=Typeface.LoadFromAssets("byekan.ttf")
   slidingmenu1.Initialize("menu")
   listview1.Initialize("list")
   slidingmenu1.BehindOffset=35%x
   slidingmenu1.Mode=slidingmenu1.LEFT
   slidingmenu1.Menu.AddView(listview1,5,5dip,82%x,100%y)
   listview1.AddTwoLinesAndBitmap2("فهرست","",LoadBitmap(File.DirAssets,"fehrest.png"),1)
   listview1.AddTwoLinesAndBitmap2("تنظیمات","",LoadBitmap(File.DirAssets,"setting.png"),2)
   listview1.AddTwoLinesAndBitmap2("تماس با ما","",LoadBitmap(File.DirAssets,"about.png"),3)
   listview1.AddTwoLinesAndBitmap2("خروج","",LoadBitmap(File.DirAssets,"exit.png"),4)
   Dim lbl As Label
   lbl=listview1.TwoLinesAndBitmap.Label
   lbl.Color=Colors.RGB(245,159,188)
   lbl.Gravity=Gravity.RIGHT
   lbl.Left=lbl.Left-120dip
   lbl.TextSize=20
   lbl.Height=100
   lbl.Typeface=font
   lbl.Top=5
   lbl.TextColor=Colors.RGB(225,0,82)
   Button1.SetBackgroundImage(LoadBitmap(File.DirAssets,"slide.png"))
   Dim gra(2) As Int
   gra(0)=Colors.RGB(225,0,82)
   gra(1)=Colors.RGB(255,255,255)
   Dim grad1 As GradientDrawable
   grad1.Initialize("TOP_BOTTOM",gra)
   slidingmenu1.Menu.Background=grad1
Sub Activity_Resume
Sub list_ItemClick(Position As Int,Value As Object)
If Position=0 Then
   StartActivity(fehrest)
   slidingmenu1.HideMenus
Else If Position=1 Then
   StartActivity(setting)
Else If Position=2 Then
   StartActivity(about)
Else If Position=3 Then
   ExitApplication
Sub Button1_Click
   If slidingmenu1.Visible=False Then
   slidingmenu1.ShowMenu
   Else If slidingmenu1.Visible=True Then
شما عین همین کدو بنویس مطمئن باش مشکلت حل میشه،درضمن هر جا سوالی بود همین جا بپرس توضیح میدم
ببخشید تو این کد تنها به این خطر گیر میده
فکر کنم کتابخونشو ندارم اگه امکان داره کتابخانشو قرار بدید اگر هم سورسش هست بذارید که به دنیا ممنون میشم
ببخشید یادم رفت کتابخونه شو بزارم
اینم لینک دانلود کتابخونه . . .
در ضمن باید همزمان کتابخونه های SlidingMenuWrapper ، SlidingPanels رو روشن کنید.
اگه کتابخومه هارو نداشتید بگید براتون میفرستم
http://s4.picofile.com/file/8181834442/SideMenuBar.zip.html
تشکر از کاربر nahid esmaelpour
بله دوست من میشه.شما به کد :
توجه کنید که یک متغییر بیتمپ داریم و از RGB استفاده شده که بر میگرده به رنگ ساید منو و بکگراندش.
مرسی آقا مجید ولی منظورم از بک گراند عکس بود
عکس میشه قرار بدیم?
مرسی ناهید خیلی ممنون اگه کتابخانه بذارید که عالی میشه ممنون
عکس واسه پس زمینش نه نمیشه ولی Logo هم میتونید واسه بالای منو ها قرار بدید.فقط میتونید به پس زمینش رنگ بدید.
