PDFWriter فارسی نوشتن
mohsen1230
من فایل pdf را توسط PDFWriter  ایجاد کردم
حال کاراکتر فارسی را در پی دی اف چطوری بنویسم
#Region  Project Attributes
    #VersionCode: 1
    #VersionName:
#End Region
#Region  Activity Attributes
    #FullScreen: False
    #IncludeTitle: True
#End Region
    Dim PDFContent As String
    Dim PDFWriter1 As PDFWriter
    Dim PaperSize As PDFPaperSizes
    Dim Fonts As PDFStandardFonts
    Dim font As Object
    Dim Label1 As Label
    If FirstTime Then
        PDFWriter1.Initialize("PDFWriter1",PaperSize.A4_WIDTH, PaperSize.A4_HEIGHT)
    font=Typeface.LoadFromAssets("b.ttf")
    Activity.LoadLayout("Main.bal")
    Activity.AddMenuItem("Make document","mnuMakeDoc")
    Activity.AddMenuItem("Save document","mnuSaveDoc")
    Activity.AddMenuItem("Show document","mnuShowDoc")
Sub Activity_Resume
Sub mnuMakeDoc_Click
Sub PDFWriter1_ConversionDone (Content As String)
    PDFContent = Content
    ProgressDialogHide
    ToastMessageShow("Conversion has been done.",False)
Sub mnuShowDoc_Click
Sub mnuSaveDoc_Click
Sub  mmmak_Click
    ProgressDialogShow("Generating Document.")
    PDFWriter1.setFont(Fonts.SUBTYPE, Fonts.TIMES_ROMAN)
    PDFWriter1.addRawContent("1 0 0 rg\n")
    PDFWriter1.addText(70, 50, 12, "This is an example of PDFWriter.")
    PDFWriter1.setFont2(Fonts.SUBTYPE, Fonts.COURIER, Fonts.WIN_ANSI_ENCODING)
    PDFWriter1.addRawContent("0 0 0 rg\n")
    PDFWriter1.addText2(30, 90, 10, "© نرم افزار هتل داری", Fonts.DEGREES_270_ROTATION)
    PDFWriter1.newPage()
    PDFWriter1.addRawContent("[] 0 d\n")
    PDFWriter1.addRawContent("1 w\n")
    PDFWriter1.addRawContent("0 0 1 RG\n")
    PDFWriter1.addRawContent("0 1 0 rg\n")
    PDFWriter1.addRectangle(40, 50, 280, 50)
    PDFWriter1.addText(85, 75, 18, "Code Research Laboratories")
    PDFWriter1.setFont(Fonts.SUBTYPE, Fonts.COURIER_BOLD)
    PDFWriter1.addText(150, 150, 14, "Ported by: RootSoft LLC.")
    PDFWriter1.addLine(150, 140, 270, 140)
    PDFWriter1.ConverseDocument
Sub mmsohw_Click
    Label1.Text = PDFWriter1.outputToScreen
Sub mmsave_Click
    PDFWriter1.addText(10, 50, 12, "This is an example of نرم افزار هتل داری")
'    PDFWriter1.setFont2(Fonts.SUBTYPE, Fonts.COURIER, font)
    PDFWriter1.setFont2(font,font,font)
    PDFWriter1.addText2(30, 90, 10, "© نرم افزار ", font)
    PDFWriter1.outputToFile(File.DirDefaultExternal,"myNewPDF1.pdf",PDFContent,"UTF-8")
    ToastMessageShow("PDF Saved.",False)
