خطای مانیفست برای google map
hocein
سلام دوستان وقت بخیر. کسی میدونه چطوری باید این خطا رو رفع کرد ؟
من از googlemapsV2 استفاده میکنم و این خطا رو بمن میده برنامه
** Activity (actmap) Create, isFirst = true **
** Activity (actmap) Resume **
java.lang.IllegalStateException: The meta-data tag in your app's AndroidManifest.xml does not have the right value.  Expected 9080000 but found 9683000.  You must have the following declaration within the <application> element:     <meta-data android:name="com.google.android.gms.version" android:value="@integer/google_play_services_version" />
	at com.google.android.gms.common.zze.zzaj(Unknown Source)
	at com.google.android.gms.common.zze.isGooglePlayServicesAvailable(Unknown Source)
	at com.google.android.gms.common.GooglePlayServicesUtil.isGooglePlayServicesAvailable(Unknown Source)
	at com.google.android.gms.maps.internal.zzad.zzba(Unknown Source)
	at com.google.android.gms.maps.internal.zzad.zzaZ(Unknown Source)
	at com.google.android.gms.maps.MapsInitializer.initialize(Unknown Source)
	at com.google.android.gms.maps.MapFragment$zzb.zzDF(Unknown Source)
	at com.google.android.gms.maps.MapFragment$zzb.zza(Unknown Source)
	at com.google.android.gms.dynamic.zza.zza(Unknown Source)
	at com.google.android.gms.dynamic.zza.onCreate(Unknown Source)
	at com.google.android.gms.maps.MapFragment.onCreate(Unknown Source)
	at android.app.Fragment.performCreate(Fragment.java:2075)
	at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:869)
	at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:1083)
	at android.app.BackStackRecord.run(BackStackRecord.java:834)
	at android.app.FragmentManagerImpl.execPendingActions(FragmentManager.java:1470)
	at android.app.FragmentManagerImpl.saveAllState(FragmentManager.java:1653)
	at android.app.Activity.onSaveInstanceState(Activity.java:1569)
	at android.app.Activity.performSaveInstanceState(Activity.java:1495)
	at android.app.Instrumentation.callActivityOnSaveInstanceState(Instrumentation.java:1316)
	at android.app.ActivityThread.callCallActivityOnSaveInstanceState(ActivityThread.java:5194)
	at android.app.ActivityThread.performStopActivityInner(ActivityThread.java:4519)
	at android.app.ActivityThread.handleStopActivity(ActivityThread.java:4582)
	at android.app.ActivityThread.access$1300(ActivityThread.java:218)
	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1742)
	at android.os.Handler.dispatchMessage(Handler.java:102)
	at android.os.Looper.loop(Looper.java:145)
	at android.app.ActivityThread.main(ActivityThread.java:6917)
	at java.lang.reflect.Method.invoke(Method.java:372)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1404)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1199)
