این چه اروریه؟دیروز برنامه خوب کار میکرد.امروز اجرا میکنم این ارور رو میده.
B4A version: 6.00
Parsing code. (0.01s)
Compiling code. (0.11s)
Compiling layouts code. (0.03s)
Organizing libraries. (1.76s)
Generating R file. (0.55s)
Compiling generated Java code. (3.94s)
Convert byte code - optimized dex. Error
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dx.cf.iface.ParseException: com.android.dx.rop.cst.CstMethodRef cannot be cast to com.android.dx.rop.cst.CstString
at com.android.dx.cf.direct.AttributeListParser.parse(AttributeListParser.java:156)
at com.android.dx.cf.direct.AttributeListParser.parseIfNecessary(AttributeListParser.java:115)
at com.android.dx.cf.direct.AttributeListParser.getList(AttributeListParser.java:106)
at com.android.dx.cf.direct.StdAttributeFactory.code(StdAttributeFactory.java:300)
at com.android.dx.cf.direct.StdAttributeFactory.parse0(StdAttributeFactory.java:139)
at com.android.dx.cf.direct.AttributeFactory.parse(AttributeFactory.java:96)
at com.android.dx.cf.direct.AttributeListParser.parse(AttributeListParser.java:141)
at com.android.dx.cf.direct.AttributeListParser.getEndOffset(AttributeListParser.java:96)
at com.android.dx.cf.direct.MemberListParser.parse(MemberListParser.java:213)
at com.android.dx.cf.direct.MemberListParser.parseIfNecessary(MemberListParser.java:108)
at com.android.dx.cf.direct.MethodListParser.getList(MethodListParser.java:54)
at com.android.dx.cf.direct.DirectClassFile.parse0(DirectClassFile.java:542)
at com.android.dx.cf.direct.DirectClassFile.parse(DirectClassFile.java:406)
at com.android.dx.cf.direct.DirectClassFile.parseToInterfacesIfNecessary(DirectClassFile.java:388)
at com.android.dx.cf.direct.DirectClassFile.getMagic(DirectClassFile.java:251)
at com.android.dx.command.dexer.Main.processClass(Main.java:598)
at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570)
at com.android.dx.command.dexer.Main.access$2(Main.java:546)
at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514)
at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
at com.android.dx.command.dexer.Main.processOne(Main.java:537)
at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236)
at com.android.dx.command.dexer.Main.run(Main.java:206)
at com.android.dx.command.dexer.Main.main(Main.java:179)
at com.android.dx.command.Main.main(Main.java:103)
Caused by: java.lang.ClassCastException: com.android.dx.rop.cst.CstMethodRef cannot be cast to com.android.dx.rop.cst.CstString
at com.android.dx.cf.direct.StdAttributeFactory.parseLocalVariables(StdAttributeFactory.java:575)
at com.android.dx.cf.direct.StdAttributeFactory.localVariableTable(StdAttributeFactory.java:517)
at com.android.dx.cf.direct.StdAttributeFactory.parse0(StdAttributeFactory.java:178)
... 28 more
...while parsing attributes[1]
...while parsing Code attribute at offset 00000606
...while parsing attributes[0]
...while parsing methods[0]
...while parsing android/support/v4/app/BaseFragmentActivityApi14.class
1 error; aborting
jchdeveloper 1
راهنمایی کنین لطفا.
