ali reza 5 ارسال شده در 10 شهریور، ۱۳۹۷ اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۷ سلام دوستان هنگام استفاده از نسخه 1.4 پوشه با خطای زیر مواجه میشم کسی میدونه این خطا یعنی چی ؟؟؟ B4A Version: 8.30 Parsing code. (0.08s) Compiling code. (0.21s) Compiling layouts code. (0.06s) Organizing libraries. (0.00s) Generating R file. (1.26s) Compiling generated Java code. (5.11s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimatorRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnyRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnyThread; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/ArrayRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AttrRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BinderThread; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BoolRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/CallSuper; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:315) at com.android.dx.command.dexer.Main.runDx(Main.java:293) at com.android.dx.command.dexer.Main.main(Main.java:249) at com.android.dx.command.Main.main(Main.java:94) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684) ... 4 more *** Legacy debugger is deprecated. *** It is recommended to switch to the default debugger (Tools - IDE Options) اینم لیست کتابخونه هایی که استفاده کردم لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمد مهدی کمالی 19 ارسال شده در 13 شهریور، ۱۳۹۷ اشتراک گذاری ارسال شده در 13 شهریور، ۱۳۹۷ قبلا به این اخطار زیاد بر خوردم با ariaglide هم احتمالا تداخل داره . به طور کلی برای رفع اخطار های تداخل یه راه ساده هست. به طور مثال کتابخونه پوشه : فایل xmlرو باز کنید با ورد پد یا هر برنامه ک فایل تکست باز میکنه اخر فایل xml چندین خط به این شکل هست: <dependsOn>support-v4</dependsOn> <dependsOn>support-annotations</dependsOn> <dependsOn>support-compat</dependsOn> <dependsOn>support-core-ui</dependsOn> <dependsOn>support-core-utils</dependsOn> <dependsOn>support-fragment</dependsOn> <dependsOn>support-media-compat</dependsOn> <dependsOn>pushe-1.4.0.aar</dependsOn> <dependsOn>play-services-base.aar</dependsOn> <dependsOn>play-services-gcm</dependsOn> <dependsOn>play-services-basement.aar</dependsOn> <dependsOn>play-services-iid</dependsOn> <dependsOn>play-services-tasks</dependsOn> <dependsOn>android-job-1.2.4.aar</dependsOn> <dependsOn>play-services-location</dependsOn> این ها بخش ها وابسطه به کتابخونن . حالا کتابخونه ای تداخل خواهد داست که عبارت مشابه اینا توش باشه . بعد از پیدا کردن کتابوخه ک تداخل دارخ فایل xml اون رو باز کن و برو اخرش کد های کشابه کد های پوشه روحذف کن مخصوصا کد هایی که اولشون support داره . یه نکته هس که کتابخونه های مختلف ممکنه با حذف کردن کد هاشون دیگه ران نشن که عمدتا کتابخونه هایی هستن که یه فایل با پسوند aar دارند مثل متریال دیالوگ یا اصلا همین پوشه. اینارو نمیشه ویرایش کرد. بعد از ویرایش هم ذخیره کنید و تمام ولی ::::::::::::::::::::::::::::::: حتما قبلش از کتابخونتون یه بکاپ بگیرید. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
M-CAP7AIN 537 ارسال شده در 10 شهریور، ۱۳۹۷ اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۷ با یکی از کتابخونه ها تداخل داره ، باید کتابخونه ها بررسی شن . ببینید از این کتابخونه android-support-annotations تو کدوم کتابخونه ها استفاده شده ، فایل xml رو ادیت کنید ، اسم این کتابخونه رو یکسان قرار بدید. یا تمامی فایل های xml کتابخونتون رو که استفاده می کنید پیوست کنید.تا بررسی بشن. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ali reza 5 ارسال شده در 12 شهریور، ۱۳۹۷ سازنده اشتراک گذاری ارسال شده در 12 شهریور، ۱۳۹۷ در در 1397/06/10, 17:15:21، M-CAP7AIN گفته است : با یکی از کتابخونه ها تداخل داره ، باید کتابخونه ها بررسی شن . ببینید از این کتابخونه android-support-annotations تو کدوم کتابخونه ها استفاده شده ، فایل xml رو ادیت کنید ، اسم این کتابخونه رو یکسان قرار بدید. یا تمامی فایل های xml کتابخونتون رو که استفاده می کنید پیوست کنید.تا بررسی بشن. مرسی از پاسختون دوست عزیز با کتابخونه اپ کامپت تداخل داره کتابخونه رو پیوست میکنم بیزحمت راهنمایی کنید دانلود appcompat لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
M-CAP7AIN 537 ارسال شده در 12 شهریور، ۱۳۹۷ اشتراک گذاری ارسال شده در 12 شهریور، ۱۳۹۷ این فایل رو جایگزین کنید. از نسخه قبلی بکاپ بگیرید. AppCompat.rar لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ali reza 5
