rasool.g 135 ارسال شده در 6 اسفند، 2018 اشتراک گذاری ارسال شده در 6 اسفند، 2018 'txt = "wg qdgh qdgqwh gdhwqg dhgwq dgwqjh gdjhwq gjhwqg jhwqg jgwq gdjh gdhg jhwdg wqjhd gwqjh dg wda dwa d ad" txt = " " & Chr(0xF114) & " " & "لورم ایپسوم متن ساختگی با تولید سادگی نامفهوم از صنعت چاپ و با استفاده از طراحان گرافیک است. " 'txt = "لورم ایپسوم متن ساختگی با تولید سادگی نامفهوم از صنعت چاپ و با استفاده از طراحان گرافیک است. " Dim l1,l2 As Label l1.Initialize("l1") l2.Initialize("l2") Activity.AddView(l1,0,0,100%x,10%y) Activity.AddView(l2,0,10%y,100%x,10%y) l1.TextSize = 20 l2.TextSize = 20 l1.Typeface = Typeface.FONTAWESOME l2.Typeface = Typeface.FONTAWESOME l1.Gravity = Gravity.RIGHT + Gravity.CENTER_VERTICAL l2.Gravity = Gravity.RIGHT + Gravity.CENTER_VERTICAL l1.SingleLine = True l2.SingleLine = True l1.Ellipsize = "END" l2.Ellipsize = "NONE" l1.Text = Chr(0x202b)& txt &Chr(0x202c) l2.Text = Chr(0x202b)& txt &Chr(0x202c) Dim lv1 As ListView lv1.Initialize("lv1") Activity.AddView(lv1,0,20%y,100%x,20%y) lv1.SingleLineLayout.Label.TextSize = 20 lv1.SingleLineLayout.Label.Typeface = Typeface.FONTAWESOME lv1.SingleLineLayout.Label.SingleLine = True lv1.SingleLineLayout.Label.Gravity = Gravity.RIGHT + Gravity.CENTER_VERTICAL lv1.SingleLineLayout.Label.Color = Colors.Gray 'lv1.SingleLineLayout.Label.Padding = Array As Int (10dip, 10dip, 10dip, 10dip) 'lv1.Padding = Array As Int (0dip, 0dip, 0dip, 0dip) lv1.Color = Colors.White lv1.SingleLineLayout.Label.Width = lv1.Width - 10dip 'or (- lv1.SingleLineLayout.Label.Left) Dim maxTL As Int = 5 lv1.AddSingleLine( Chr(0x202b)& txt &Chr(0x202c) ) Dim maxWidth As Int = lv1.Width - 10dip' - 20dip maxWidth = maxWidth * 0.95 Dim Canvas1,c1 As Canvas c1.Initialize(Activity) Dim b As Bitmap b.InitializeMutable(1dip,1dip) Canvas1.Initialize2(b) 'c1.DrawText(txt, 0, 10%y, l1.Typeface, 20, Colors.White, "LEFT") Dim maxTL As Int = 2 For i = txt.Length To 5 Step -1 Log(i) If c1.MeasureStringWidth(txt.SubString2(0,i) & "...",l1.Typeface,20) <= maxWidth Then maxTL = i Exit End If Next Log(maxTL) l2.Text = Chr(0x202b)&txt.SubString2(0,maxTL) & "..."&Chr(0x202c) lv1.AddSingleLine(Chr(0x202b) &txt.SubString2(0,maxTL) & "..."&Chr(0x202c)) c1.DrawText("["&txt.SubString2(0,maxTL)&"...]", 0, 60%y, l1.Typeface, 20, Colors.White, "LEFT") c1.DrawText(txt.SubString2(0,maxTL)&"...", 0, 80%y, l1.Typeface, 20, Colors.White, "LEFT") Log("-----") لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
rasool.g 135 ارسال شده در 6 اسفند، 2018 سازنده اشتراک گذاری ارسال شده در 6 اسفند، 2018 برای اندازه گیری در کد بالا از Canvas1 هم می تونید استفاده کنید. مقدار Step در حلقه رو برای افزایش سرعت میشه بیشتر کرد. Chr(0x202b) و Chr(0x202c) رو فقط برای راست به چپ کردن گذاشتم. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
