میخوام زمانی روی باتون کلیک میکنم به متن لیبل که int هست یکی اضافه بشه
ولی مشکل اینجاس زمانی که روی هر باتون کلیک میکنم فقط متن لیبل اخرین پنل تغییر میکنه
ممنون میشم کمک کنید.
Dim sql As SQL
Dim cur As Cursor
Dim s As Int
Private Button1 As Button
Private Label1 As Label
Private Label2 As Label
Dim num As Int = 1
Dim offset As Int = 0
Private Label3 As Label
Sub Activity_Create(FirstTime As Boolean
Activity.LoadLayout("scroll")
If File.Exists(File.DirInternal,"db.db") = False Then
File.Copy(File.DirAssets,"db.db",File.DirInternal,"db.db")
If sql.IsInitialized = False Then
sql.Initialize(File.DirInternal,"db.db",False)
show("SELECT * FROM tbl LIMIT 10 OFFSET "&offset&"")
Sub show(query As String)
cur = sql.ExecQuery(query)
For i = 0 To cur.RowCount-1
cur.Position = i
Dim p As Panel
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,s,96%x,100%y)
s = s + 27%y
p.LoadLayout("main")
Label1.text = cur.GetString("name")
Label2.Text = cur.GetString("famil")
Button1.Tag = cur.GetString("id")
Label3.Tag = cur.GetString("id")
ScrollView1.Panel.Height = s
ScrollView1.Panel.Color = Colors.Transparent
Sub Button1_Click
num = num +1
Dim b As Button
b = Sender
Label3.Text = num
ToastMessageShow("clicked id : " & b.Tag,False)
Sub ScrollView1_ScrollChanged(Position As Int)
If ScrollView1.ScrollPosition + ScrollView1.Height = ScrollView1.Panel.Height Then
offset = offset + 10
Sub Activity_Resume
Mr Silence 137
Sub Process_Globals Dim sql As SQL Dim cur As Cursor End Sub Sub Globals Dim s As Int Private Button1 As Button Private Label1 As Label Private Label2 As Label Private ScrollView1 As ScrollView Dim num As Int = 1 Dim offset As Int = 0 Private Label3 As Label End Sub Sub Activity_Create(FirstTime As Boolean Activity.LoadLayout("scroll") If File.Exists(File.DirInternal,"db.db") = False Then File.Copy(File.DirAssets,"db.db",File.DirInternal,"db.db") End If If sql.IsInitialized = False Then sql.Initialize(File.DirInternal,"db.db",False) End If show("SELECT * FROM tbl LIMIT 10 OFFSET "&offset&"") Sub show(query As String) cur = sql.ExecQuery(query) For i = 0 To cur.RowCount-1 cur.Position = i Dim p As Panel p.Initialize("p") ScrollView1.Panel.AddView(p,0,s,96%x,100%y) s = s + 27%y p.LoadLayout("main") Label1.text = cur.GetString("name") Label2.Text = cur.GetString("famil") Button1.Tag = cur.GetString("id") Label3.Tag = cur.GetString("id") ScrollView1.Panel.Height = s ScrollView1.Panel.Color = Colors.Transparent Next End Sub Sub Button1_Click num = num +1 Dim b As Button b = Sender Label3.Text = num ToastMessageShow("clicked id : " & b.Tag,False) End Sub Sub ScrollView1_ScrollChanged(Position As Int) If ScrollView1.ScrollPosition + ScrollView1.Height = ScrollView1.Panel.Height Then offset = offset + 10 show("SELECT * FROM tbl LIMIT 10 OFFSET "&offset&"") End If End Sub End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub
