من تازه کار با کتابخانه AppCompat رو شروع کردم جند آموزش هم توی همین انجمن دیدم و همه چی خوب پیش رفت تا اینکه الان میخوام یک منوی ساده در Actionbar که ساختم قرار بدم که متاسفانه نمیشه خطا هم نمیده کد تست رو قرار میدم لطفا بگین مشکل از چیه
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#Extends: android.support.v7.app.AppCompatActivity
#End Region
Dim men As ACMenuItem
Dim ser As ACSearchView
Private Button1 As Button
Dim spinner1 As Spinner
#If Java
public boolean _onCreateOptionsMenu(android.view.Menu menu) {
if (processBA.subExists("activity_createmenu")) {
processBA.raiseEvent2(null, true, "activity_createmenu", false, new de.amberhome.objects.appcompat.ACMenuWrapper(menu));
return true;
else
return false;
#End If
spinner1.Initialize("spinner")
spinner1.AddAll(Array("Number1", "Number2", "Number3", "Number4", "Number5", "Number6", "Number7"))
Dim p As Phone
If p.SdkVersion < 11 Then
spinner1.DropdownBackgroundColor = Colors.DarkGray
spinner1.DropdownTextColor = Colors.White
spinner1.TextColor = Colors.White
Else If p.SdkVersion < 21 Then
Activity.AddMenuItem("Mahdi", "Menu")
Activity.AddMenuItem("Arian", "Menu")
Activity.AddMenuItem("Armin", "Menu")
Activity.AddMenuItem("Arash", "Menu")
Activity.LoadLayout("lmain")
ForseRtlSupported
Sub Activity_CreateMenu(menus As ACMenu)
ser.Initialize2("search" , ser.THEME_DARK)
ser.IconifiedByDefault=True
menus.Clear
men=menus.Add2(1,1,"سرج" , Null)
men.SearchView=ser
Sub Activity_Resume
Sub ForseRtlSupported
Dim j1,j2 As JavaObject
j2.InitializeStatic("android.view.View")
If j1.InitializeStatic ("android.os.Build$VERSION").GetField ("SDK_INT") > 16 Then
j1.InitializeContext.RunMethodJO("getWindow",Null).RunMethodJO("getDecorView",Null) _
.RunMethod ("setLayoutDirection",Array(j2.GetField ("LAYOUT_DIRECTION_RTL")))
Sub Button1_Click
StartActivity(apptest)
amir_7 0
#Region Activity Attributes #FullScreen: False #IncludeTitle: True #Extends: android.support.v7.app.AppCompatActivity #End Region Sub Process_Globals End Sub Sub Globals Dim men As ACMenuItem Dim ser As ACSearchView Private Button1 As Button Dim spinner1 As Spinner End Sub #If Java public boolean _onCreateOptionsMenu(android.view.Menu menu) { if (processBA.subExists("activity_createmenu")) { processBA.raiseEvent2(null, true, "activity_createmenu", false, new de.amberhome.objects.appcompat.ACMenuWrapper(menu)); return true; } else return false; } #End If Sub Activity_Create(FirstTime As Boolean) spinner1.Initialize("spinner") spinner1.AddAll(Array("Number1", "Number2", "Number3", "Number4", "Number5", "Number6", "Number7")) Dim p As Phone If p.SdkVersion < 11 Then spinner1.DropdownBackgroundColor = Colors.DarkGray spinner1.DropdownTextColor = Colors.White spinner1.TextColor = Colors.White Else If p.SdkVersion < 21 Then spinner1.DropdownBackgroundColor = Colors.DarkGray End If Activity.AddMenuItem("Mahdi", "Menu") Activity.AddMenuItem("Arian", "Menu") Activity.AddMenuItem("Armin", "Menu") Activity.AddMenuItem("Arash", "Menu") Activity.LoadLayout("lmain") ForseRtlSupported End Sub Sub Activity_CreateMenu(menus As ACMenu) ser.Initialize2("search" , ser.THEME_DARK) ser.IconifiedByDefault=True menus.Clear men=menus.Add2(1,1,"سرج" , Null) men.SearchView=ser End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub ForseRtlSupported Dim j1,j2 As JavaObject j2.InitializeStatic("android.view.View") If j1.InitializeStatic ("android.os.Build$VERSION").GetField ("SDK_INT") > 16 Then j1.InitializeContext.RunMethodJO("getWindow",Null).RunMethodJO("getDecorView",Null) _ .RunMethod ("setLayoutDirection",Array(j2.GetField ("LAYOUT_DIRECTION_RTL"))) End If End Sub Sub Button1_Click StartActivity(apptest) End Subهمه قسمتا حتی سرج ب خوبی کار میکنه غیر از منو !!!
