تداخل کتابخانه پوشه
Javad25564
سلام.بچها چیکار کنم کتابخانه پوشه را اضافه میکنم خطای زیر را میده
B4A Version: 8.80
Parsing code.    (0.13s)
Building folders structure.    (0.02s)
Compiling code.    (12.43s)
Compiling layouts code.    (0.18s)
Organizing libraries.    (0.00s)
Generating R file.    (7.40s)
Compiling debugger engine code.    (9.08s)
Compiling generated Java code.    (15.73s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimatorRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnyRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnyThread;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/ArrayRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AttrRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BinderThread;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BoolRes;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/CallSuper;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:315)
	at com.android.dx.command.dexer.Main.runDx(Main.java:293)
	at com.android.dx.command.dexer.Main.main(Main.java:249)
	at com.android.dx.command.Main.main(Main.java:94)
Caused by: java.lang.InterruptedException: Too many errors
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684)
	... 4 more
در 4 ساعت قبل، godping گفته است :
منم همین مشکلو دارم حل نشد مجبور شدم برم سراغ چشمک
کار با چشمک خوبه؟؟
در 7 ساعت قبل، hosseinkarimyan گفته است :
سلام این با کتابخانه appcompad فکر کنم تداخل داره برای حل بهترین راه این هست کتابخانه زیر دانلود و جایگزین کنید :
http://s9.picofile.com/file/8353535184/b4a_no_conflict.zip.html
توجه این کد رو حتما در اکتیویتی قرار بدین
Dim p As Pushe
	p.initialize()
	p.getPusheId()
	Log("pusheId is :" & p.getPusheId())
	If p.pusheInitialized() Then
		p.sendSimpleNotifToUser(p.getPusheId(), "hi", "simple notif from this app to this device")
اوکی شد.
در در 1397/12/10, 18:28:52، mohammade79 گفته است :
عزیزم شما میتونی یه سمپل قدیمی از کد مانیفست و لایبری قدیمی رو استفاده کنی من هعم همین کارو کردم یه سمپل میدم بهت
'See this link for for more information: https://www.b4x.com/forum/showthread.php?p=78136
AddManifestText(
<uses-sdk android:minSdkVersion="5" android:targetSdkVersion="22"/>
    android:normalScreens="true"
    android:smallScreens="true"
    android:anyDensity="true"/>)
'CreateResourceFromFile(Macro, Themes.DarkTheme)
SetApplicationAttribute(android:supportsRtl, "true")
SetApplicationAttribute(android:theme, "@style/MyAppTheme")
AddPermission("android.permission.INTERNET")
AddPermission("android.permission.READ_PHONE_STATE")
AddManifestText(<uses-permission android:name="android.permission.GET_ACCOUNTS" />)
CreateResource(values, theme.xml,
<resources>
    <style name="MyAppTheme" parent="Theme.AppCompat.Light.NoActionBar">
        <item name="colorPrimary">#292d33</item>
        <item name="colorPrimaryDark">#292d33</item>
        <item name="colorAccent">#292d33</item>
        <item name="windowNoTitle">true</item>
        <item name="windowActionBar">false</item>
    </style>
</resources>
CreateResource(values-v21, theme.xml,
<resources>
		<item name="android:windowTranslucentStatus">false</item>
        <item name="android:windowTranslucentNavigation">false</item>
		<item name="android:windowDrawsSystemBarBackgrounds">false</item>
        <item name="android:fitsSystemWindows">true</item>
    </style>
</resources>
AddManifestText(
<permission
        android:name="com.appdroids.movietimes.permission.C2D_MESSAGE"
        android:protectionLevel="signature" />
<uses-permission android:name="com.appdroids.movietimes.permission.C2D_MESSAGE" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
'optional permissions
AddManifestText(
<uses-permission android:name="android.permission.READ_PHONE_STATE"/>
<uses-permission android:name="com.google.android.gms.permission.ACTIVITY_RECOGNITION"/>
AddApplicationText(
<receiver android:name="co.ronash.pushe.receiver.UpdateReceiver" >
<intent-filter>
    <action android:name="android.intent.action.PACKAGE_REPLACED" />
    <data
            android:path="com.appdroids.movietimes"
            android:scheme="package" />
</intent-filter>
</receiver>
<receiver
android:name="com.google.android.gms.gcm.GcmReceiver"
android:exported="true"
android:permission="com.google.android.c2dm.permission.SEND" >
<intent-filter>
    <action android:name="com.google.android.c2dm.intent.RECEIVE" />
    <action android:name="com.google.android.c2dm.intent.REGISTRATION" />
    <category android:name="com.appdroids.movietimes" />
</intent-filter>
</receiver>
<service
android:name="co.ronash.pushe.service.GcmService"
android:exported="false" >
<intent-filter>
</intent-filter>
</service>
<receiver
android:name="co.ronash.pushe.receiver.FallbackGcmNetworkManagerReceiver"
android:exported="true" >
<intent-filter>
    <action android:name="co.ronash.pushe.CHECK_TASKS" />
</intent-filter>
</receiver>
<service
android:name="co.ronash.pushe.service.FallbackGcmTaskRunner"
<intent-filter>
    <action android:name="co.ronash.pushe.ACTION_TASK_READY" />
</intent-filter>
</service>
<service
android:name="co.ronash.pushe.task.scheduler.gcm.GcmTaskRunner"
android:permission="com.google.android.gms.permission.BIND_NETWORK_TASK_SERVICE" >
<intent-filter>
    <action android:name="com.google.android.gms.gcm.ACTION_TASK_READY" />
</intent-filter>
</service>
<service
android:name="co.ronash.pushe.service.IntentTaskRunner"
android:exported="false" />
<service
android:name="co.ronash.pushe.service.InstanceIDService"
<intent-filter>
    <action android:name="com.google.android.gms.iid.InstanceID" />
</intent-filter>
</service>
<activity
android:name="co.ronash.pushe.activities.PopupDialogActivity"
android:theme="@style/PusheTransparent">
</activity>
<receiver android:name="co.ronash.pushe.receiver.BootAndScreenReceiver">
<intent-filter>
    <action android:name="android.intent.action.BOOT_COMPLETED"/>
</intent-filter>
</receiver>
<service android:name="co.ronash.pushe.service.ScreenStateService">
<intent-filter>
    <action android:name="co.ronash.pushe.service.ScreenStateService" />
</intent-filter>
</service>
<activity
android:name="co.ronash.pushe.activities.WebviewActivity">
</activity>
<receiver android:name="co.ronash.pushe.receiver.AppUsageAlarmReceiver">
</receiver>
<receiver android:name="co.ronash.pushe.receiver.ConnectivityReceiver">
<intent-filter>
    <action android:name="android.net.conn.CONNECTIVITY_CHANGE"/>
</intent-filter>
</receiver>
<receiver
android:name="co.ronash.pushe.receiver.AddReceiver"
android:exported="false">
<intent-filter>
    <action android:name="com.evernote.android.job.ADD_JOB_CREATOR"/>
</intent-filter>
</receiver>
<receiver android:name="co.ronash.pushe.receiver.AppChangeReceiver">
<intent-filter>
    <action android:name="android.intent.action.PACKAGE_INSTALL" />
    <action android:name="android.intent.action.PACKAGE_ADDED" />
    <action android:name="android.intent.action.PACKAGE_FULLY_REMOVED" />
    <data android:scheme="package"/>
</intent-filter>
</receiver>
<service
android:name="com.evernote.android.job.v21.PlatformJobService"
android:permission="android.permission.BIND_JOB_SERVICE" />
<service
android:name="com.evernote.android.job.v14.PlatformAlarmService"
<receiver
android:name="com.evernote.android.job.v14.PlatformAlarmReceiver"
<intent-filter>
    <action android:name="com.evernote.android.job.v14.RUN_JOB" />
    <action android:name="net.vrallev.android.job.v14.RUN_JOB" />
</intent-filter>
</receiver>
<receiver
android:name="com.evernote.android.job.JobBootReceiver"
<intent-filter>
    <action android:name="android.intent.action.BOOT_COMPLETED" />
</intent-filter>
</receiver>
<service
android:name="com.evernote.android.job.gcm.PlatformGcmService"
android:permission="com.google.android.gms.permission.BIND_NETWORK_TASK_SERVICE">
<intent-filter>
    <action android:name="com.google.android.gms.gcm.ACTION_TASK_READY"/>
</intent-filter>
</service>
<activity
android:name="co.ronash.pushe.activities.RequestAccessDialogActivity"
android:theme="@style/PusheTransparent" >
</activity>
<service android:name="co.ronash.pushe.service.PusheActivityService"/>
    <meta-data android:name="com.google.android.gms.version" android:value="@integer/google_play_services_version"/>
    <meta-data android:name="co.ronash.pushe.token" android:value="اینجا رو کد خودتو بزن "/>
    <meta-data android:name="co.ronash.pushe.cr" android:value="اینجا کد خودتو بنزن"/>
اونچیزی که توی سایت پوشه گفته کتابخونه قدیمی بدون firebase هست و منقضی شده و از طرف گوگل تا چند ماه دیگه بیشتر بهش سرویس داده نمیشه
AddManifestText(
<resources>
    </style>
</resources>
<resources>
    </style>
</resources>
AddManifestText(
<permission
AddManifestText(
AddApplicationText(
<intent-filter>
    <data
</intent-filter>
</receiver>
<receiver
<intent-filter>
</intent-filter>
</receiver>
<service
<intent-filter>
</intent-filter>
</service>
<receiver
<intent-filter>
</intent-filter>
</receiver>
<service
<intent-filter>
</intent-filter>
</service>
<service
<intent-filter>
</intent-filter>
</service>
<service
<service
<intent-filter>
</intent-filter>
</service>
<activity
</activity>
<intent-filter>
</intent-filter>
</receiver>
<intent-filter>
</intent-filter>
</service>
<activity
</activity>
</receiver>
<intent-filter>
</intent-filter>
</receiver>
<receiver
<intent-filter>
</intent-filter>
</receiver>
<intent-filter>
</intent-filter>
</receiver>
<service
<service
<receiver
<intent-filter>
</intent-filter>
</receiver>
<receiver
<intent-filter>
</intent-filter>
</receiver>
<service
<intent-filter>
</intent-filter>
</service>
<activity
</activity>
در 13 ساعت قبل، Javad25564 گفته است :
B4A Version: 8.80
	... 4 more
Dim p As Pushe
	p.initialize()
	p.getPusheId()
