سلام برنامه من هنگام خروجی گرفتن این ارور رو میده لطفا کمک کنید
mohammad4837
B4A Version: 8.00
Parsing code.    (0.02s)
Compiling code.    (0.27s)
Compiling layouts code.    (0.02s)
Organizing libraries.    (0.00s)
Generating R file.    (0.27s)
Compiling generated Java code.    (2.27s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmListenerService;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmListenerService$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmListenerService$2;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmNetworkManager;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmPubSub;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmReceiver;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmTaskService;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GcmTaskService$zza;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689)
    at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313)
    at com.android.dx.command.dexer.Main.run(Main.java:279)
    at com.android.dx.command.dexer.Main.main(Main.java:247)
    at com.android.dx.command.Main.main(Main.java:106)
Caused by: java.lang.InterruptedException: Too many errors
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681)
    ... 4 more
دوست عزیز بهتره از خطا اسرین شات بگیری بفرستی
و بگید که از چه کتابخونه هایی استفاده کردید؟
کتابخانه ها تداخل دارن با هم عزیز. باید ویرایش بشن
