ارور کامپایل
sina amjadi
سلام دوستان وقت همگی به خیر و سلامتی
من این ارور رو دارم ممنون میشم اگه راهنمایی کنید
B4A Version: 8.00
Parsing code.    (0.09s)
Compiling code.    (0.36s)
Compiling layouts code.    (0.02s)
Organizing libraries.    (0.00s)
Generating R file.    (2.29s)
Compiling generated Java code.    (6.48s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/DialogAction;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/DialogBase;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/DialogInit;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/GravityEnum;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/GravityEnum$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/MaterialDialog;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/MaterialDialog$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/MaterialDialog$1$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/afollestad/materialdialogs/MaterialDialog$2;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689)
    at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313)
    at com.android.dx.command.dexer.Main.run(Main.java:279)
    at com.android.dx.command.dexer.Main.main(Main.java:247)
    at com.android.dx.command.Main.main(Main.java:106)
Caused by: java.lang.InterruptedException: Too many errors
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681)
    ... 4 more
این خطا مربوط میشه به تداخل بین کتابخانه ها، از لیست کتابخانه های تیک زده شده یک اسکرین شات بگذارید.
