m_gh1389 0 ارسال شده در 6 آذر، 2019 اشتراک گذاری ارسال شده در 6 آذر، 2019 با سلام خدمت دوستان هنگام خروجی پکیج تبلیغات عدد برای تست در یونیتی 5.6 دو خطای زیر مشاهده میشه کسی می دونه مشکل کجاست؟ Failed to compile resources with the following parameters: -bootclasspath "C:\Users\yeganeh\AppData\Local\Andriod\android-sdk2\platforms\android-29\android.jar" -d "C:\Users\yeganeh\Desktop\adadunitydemo-master\Temp\StagingArea\bin\classes" -source 1.6 -target 1.6 -encoding UTF-8 "com\google\android\gms\ads\impl\R.java" "com\google\android\gms\base\R.java" "com\google\android\gms\common\R.java" "com\google\android\gms\gcm\R.java" "com\google\android\gms\iid\R.java" "com\google\android\gms\location\R.java" "com\google\android\gms\stats\R.java" "com\google\android\gms\tasks\R.java" "com\yekta\chalamat\R.java" "ir\adad\ad\R.java" "ir\adad\banner\R.java" "ir\adad\core\R.java" "ir\adad\fullscreen\R.java" "ir\adad\unity\R.java" "ir\adad\video\R.java" warning: C:\Users\yeganeh\AppData\Local\Andriod\android-sdk2\platforms\android-29\android.jar(java/lang/Object.class): major version 52 is newer than 51, the highest major version supported by this compiler. It is recommended that the compiler be upgraded. warning: C:\Users\yeganeh\AppData\Local\Andriod\android-sdk2\platforms\android-29\android.jar(java/lang/AutoCloseable.class): major version 52 is newer than 51, the highest major version supported by this compiler. It is recommended that the compiler be upgraded. 2 warnings UnityEditor.HostView:OnGUI() UnityException: Resource compilation failed! Failed to recompile android resource files. See the Console for details. UnityEditor.Android.PostProcessor.CancelPostProcess.AbortBuild (System.String title, System.String message, UnityEditor.Android.CommandInvokationFailure ex) UnityEditor.Android.PostProcessor.CancelPostProcess.AbortBuildPointToConsole (System.String title, System.String message) UnityEditor.Android.PostProcessor.Tasks.BuildResources.CompileResources (UnityEditor.Android.PostProcessor.PostProcessorContext context) UnityEditor.Android.PostProcessor.Tasks.BuildResources.Execute (UnityEditor.Android.PostProcessor.PostProcessorContext context) UnityEditor.Android.PostProcessor.PostProcessRunner.RunAllTasks (UnityEditor.Android.PostProcessor.PostProcessorContext context) UnityEditor.Android.PostProcessAndroidPlayer.PostProcess (BuildTarget target, System.String stagingAreaData, System.String stagingArea, System.String playerPackage, System.String installPath, System.String companyName, System.String productName, BuildOptions options, UnityEditor.RuntimeClassRegistry usedClassRegistry) UnityEditor.Android.AndroidBuildPostprocessor.PostProcess (BuildPostProcessArgs args) UnityEditor.PostprocessBuildPlayer.Postprocess (BuildTargetGroup targetGroup, BuildTarget target, System.String installPath, System.String companyName, System.String productName, Int32 width, Int32 height, System.String downloadWebplayerUrl, System.String manualDownloadWebplayerUrl, BuildOptions options, UnityEditor.RuntimeClassRegistry usedClassRegistry, UnityEditor.BuildReporting.BuildReport report) (at C:/buildslave/unity/build/Editor/Mono/BuildPipeline/PostprocessBuildPlayer.cs:186) UnityEditor.HostView:OnGUI() لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
