قفل کردن استاتوس و خطای ترسیم در اندروید جدید
salmana
قبلنا با لینک پایین راحت استاسو رو قفل میکردیم
https://www.b4x.com/android/forum/threads/disable-access-to-the-statusbar-notification-bar.49701/
در این لینک بالا کدهایی بصورت پایین قرار داده شده
#Region Code to disable access to the StatusBar
'Code translated by Erel:
'http://www.b4x.com/android/forum/threads/overlay-over-the-status_bar.49221/#post-309833
'Original source code:
'http://stackoverflow.com/questions/9815901/display-view-above-status-bar/25384365#25384365
Sub AddOverlay
Dim mView As Label
    mView.Initialize("")
    mView.Text = Sentence
    Dim mlp As JavaObject
    Dim vtype As Int = -1, pixelFormat As Int = -3
    mlp.InitializeNewInstance("android.view.WindowManager$LayoutParams", Array(vtype, 100, 2010,296, pixelFormat))
    mlp.SetField("gravity", Bit.OR(Gravity.TOP, Gravity.CENTER))
    Dim windowManager As JavaObject = GetContext.RunMethod("getSystemService", Array("window"))
    windowManager.RunMethod("addView", Array(mView, mlp))
Sub GetContext As JavaObject
    Return GetBA.GetField("context")
Sub GetBA As JavaObject
    Dim jo As JavaObject
    Dim cls As String = Me
    cls = cls.SubString("class ".Length)
    jo.InitializeStatic(cls)
    Return jo.GetFieldJO("processBA")
#End Region
در اندروید جدیدا خطای پایین میاد
Error occurred on line: 66 (lockstatus)
java.lang.reflect.InvocationTargetException
	at anywheresoftware.b4j.object.JavaObject.RunMethod(JavaObject.java:131)
	at b4a.test.lockstatus._addoverlay(lockstatus.java:263)
	at b4a.test.lockstatus._service_start(lockstatus.java:390)
	at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
	at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348)
	at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
	at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
	at anywheresoftware.b4a.BA.raiseEvent(BA.java:176)
	at b4a.test.lockstatus.handleStart(lockstatus.java:100)
	at b4a.test.lockstatus.access$000(lockstatus.java:8)
	at b4a.test.lockstatus$1.run(lockstatus.java:71)
	at anywheresoftware.b4a.objects.ServiceHelper$StarterHelper.onStartCommand(ServiceHelper.java:237)
	at b4a.test.lockstatus.onStartCommand(lockstatus.java:69)
	at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:3885)
	at android.app.ActivityThread.access$1700(ActivityThread.java:237)
	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
	at android.os.Handler.dispatchMessage(Handler.java:106)
	at android.os.Looper.Loop(Looper.java:214)
	at android.app.ActivityThread.main(ActivityThread.java:7045)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:964)
Caused by: android.view.WindowManager$BadTokenException: Unable To add window android.view.ViewRootImpl$W@d8ef02f -- permission denied For window Type 2010
	at android.view.ViewRootImpl.setView(ViewRootImpl.java:1064)
	at android.view.WindowManagerGlobal.addView(WindowManagerGlobal.java:381)
	at android.view.WindowManagerImpl.addView(WindowManagerImpl.java:93)
	... 25 more
لاین 66 هم اینه :
با تشکر
در 5 دقیقه قبل، salmana گفته است :
یه لیبل میاد روی استاتوس بار و طرف هر چی میاد استاتوس رو از بالا به پایین بکشه(و نوتیفیکیشنها رو ببینه) نمیتونه و اصلا نمیشه از بالا به پایین بکشیم.
قبلنا جواب میداد ولی تو اندروید جدید خطای ترسیم میده. یعنی این:
البته من بعید میدونم که تو اندروید جدید شدنی باشه ولی کد رو براتون اصلاح میکنم تست کنید ببینید کار میکنه یا نه.
تو کدهای بالا همه چیش رو ثابت بزارید فقط خط زیر به جای 2010 عدد 2036 رو بزارید برای اندروید بالای 8  (api 28) و برای پایین تر از ۸ عدد 2002 رو قرار بدید.
این دوتا پرمیشنو به manifest اضافه کنید ببینید مشکل حل میشه یا نه
AddPermission(android.permission.INTERNAL_SYSTEM_WINDOW)
AddPermission(android.permission.SYSTEM_ALERT_WINDOW)
در 10 دقیقه قبل، godping گفته است :
از قبل این دسترسی ها داده بودم
منظورتون از قفل کردن چیه دوست عزیز؟ دقیقا چه اتفاقی میخواین بیفته؟
در 9 ساعت قبل، محمدرضا شاهپیری گفته است :
