من نمیدونم چرا از بعضی از ویوهای متریالی استفاده میکنم، برنامم خطا میده!!
مثلا از
ACBotton
استفاده میکنم همه چی اوکیه، اما از
ACSpinner
استفاده میکنم این ارور رو میده
Error occurred on line: 0 (alarm_clock_weekly_main)
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:170)
at anywheresoftware.b4a.objects.ActivityWrapper.LoadLayout(ActivityWrapper.java:209)
at ir.morteza.alarm.alarm_clock_weekly_main._activity_create(alarm_clock_weekly_main.java:385)
at java.lang.reflect.Method.invoke(Method.java:511)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
at ir.morteza.alarm.alarm_clock_weekly_main.afterFirstLayout(alarm_clock_weekly_main.java:104)
at ir.morteza.alarm.alarm_clock_weekly_main.access$000(alarm_clock_weekly_main.java:17)
at ir.morteza.alarm.alarm_clock_weekly_main$WaitForLayout.run(alarm_clock_weekly_main.java:82)
at android.os.Handler.handleCallback(Handler.java:605)
at android.os.Handler.dispatchMessage(Handler.java:92)
at android.os.Looper.loop(Looper.java:137)
at android.app.ActivityThread.main(ActivityThread.java:4424)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
Caused by: java.lang.reflect.InvocationTargetException
at anywheresoftware.b4a.objects.CustomViewWrapper.AfterDesignerScript(CustomViewWrapper.java:64)
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:162)
... 22 more
Caused by: android.content.res.Resources$NotFoundException: File res/drawable/abc_vector_test.xml from drawable resource ID #0x7f020053
at android.content.res.Resources.loadDrawable(Resources.java:1923)
at android.content.res.Resources.getDrawable(Resources.java:664)
at android.support.v4.content.ContextCompat.getDrawable(ContextCompat.java:479)
at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:203)
at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:191)
at android.support.v7.widget.AppCompatDrawableManager.checkVectorDrawableSetup(AppCompatDrawableManager.java:753)
at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:196)
at android.support.v7.content.res.AppCompatResources.getDrawable(AppCompatResources.java:102)
at android.support.v7.widget.TintTypedArray.getDrawable(TintTypedArray.java:76)
at android.support.v7.widget.AppCompatPopupWindow.init(AppCompatPopupWindow.java:57)
at android.support.v7.widget.AppCompatPopupWindow.<init>(AppCompatPopupWindow.java:47)
at android.support.v7.widget.ListPopupWindow.<init>(ListPopupWindow.java:270)
at android.support.v7.widget.ListPopupWindow.<init>(ListPopupWindow.java:242)
at android.support.v7.widget.AppCompatSpinner$DropdownPopup.<init>(AppCompatSpinner.java:723)
at android.support.v7.widget.AppCompatSpinner.<init>(AppCompatSpinner.java:235)
at android.support.v7.widget.AppCompatSpinner.<init>(AppCompatSpinner.java:167)
at android.support.v7.widget.AppCompatSpinner.<init>(AppCompatSpinner.java:148)
at android.support.v7.widget.AppCompatSpinner.<init>(AppCompatSpinner.java:133)
at android.support.v7.widget.AppCompatSpinner.<init>(AppCompatSpinner.java:107)
at de.amberhome.objects.appcompat.ACSpinnerWrapper$ACB4ASpinner.<init>(ACSpinnerWrapper.java:371)
at de.amberhome.objects.appcompat.ACSpinnerWrapper.innerInitialize(ACSpinnerWrapper.java:74)
at anywheres
Message longer than Log limit (4000). Message was truncated.
** Activity (alarm_clock_weekly_main) Resume **
MR.B4A 220
سلام به همه
مثلا از
ACBotton
ACSpinner
... 22 more
at anywheres
و از برنامه خارج میشه
ممنون میشم کمکم کنید که دلیلش چیه
