خطای appcompad بعد اپدیت sdk اندروید x
hosseinkarimian
 باسلام هنگام استفاده appcompad بعد اپدیت sdk که برای اندروید x اپدیت کردم با خطای زیر مواجه میشم  البته در زمان اجرا وقتی مثلا در کد زیر
	Dim acb As ACButton
acb.Initialize("abc")
Activity.AddView(acb,PerXToCurrent(10),PerYToCurrent(10),PerXToCurrent(20),PerYToCurrent(20))
توی خط acb.Initialize("abc") خطای زیر میده
java.lang.NoClassDefFoundError: Failed resolution of: Landroid/support/v7/widget/AppCompatButton;
	at de.amberhome.objects.appcompat.internal.InternalACButtonWrapper.innerInitialize(InternalACButtonWrapper.java:132)
	at anywheresoftware.b4a.objects.ViewWrapper.Initialize(ViewWrapper.java:67)
	at de.amberhome.objects.appcompat.internal.InternalACButtonWrapper.Initialize(InternalACButtonWrapper.java:115)
	at anywheresoftware.b4a.shell.Shell.runVoidMethod(Shell.java:777)
	at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:354)
	at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
	at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
	at b4a.example2222.main.afterFirstLayout(main.java:104)
	at b4a.example2222.main.access$000(main.java:17)
	at b4a.example2222.main$WaitForLayout.run(main.java:82)
	at android.os.Handler.handleCallback(Handler.java:873)
	at android.os.Handler.dispatchMessage(Handler.java:99)
	at android.os.Looper.loop(Looper.java:214)
	at android.app.ActivityThread.main(ActivityThread.java:7099)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:494)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:965)
Caused by: java.lang.ClassNotFoundException: Didn't find class "android.support.v7.widget.AppCompatButton" on path: DexPathList[[zip file "/system/framework/org.apache.http.legacy.boot.jar", zip file "/data/app/b4a.example2222-wCfH8C1IShYHR-zXt4mqKA==/base.apk"],nativeLibraryDirectories=[/data/app/b4a.example2222-wCfH8C1IShYHR-zXt4mqKA==/lib/arm64, /system/lib64]]
	at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:134)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
	... 19 more
** Activity (main) Resume **
Error occurred on line: 48 (Main)
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Boolean
همچنین کتابخانه ها رو هم jetifier  کردم
از SDK Manager فایل ها و SDK رو اپدیت کن
مرحله دوم jetfier کن
مرحله اخر از tools روی Clean Project کلیک کن
b4a ریستارت کن درست میشه
از آخرین ورژن کتابخونه AppCompat استفاده کن . ورژن 4.00
در در 19 دی 1398 در 23:54، Mr Silence گفته است :
sdk کامل اپدیت کردم  ، jetfier کردم - AppCompat  4.00 دارم باز همین خطا میدم از b4a 9.50  استفاده می کنم ولی احتمال زیاد مشکل  sdk .
دوستان sdk خودون که مشکلی نداشته با کتابخانه  های  AppCompat    و    PersianRecyclerView ممنون میشم آپلود کنید چون مشکل خیلی از دوستان با اندروید x :53:
Clean project هم کردید؟
چون خودم دقیقا همین مشکل داشتم با اندروید ایکس و برطرف شد
در ۱ ساعت قبل، Mr Silence گفته است :
اره ، مشکل از sdk اگه بتونید sdk آپلود کنید مشکل خیلی دوستان توی اندروید x حل میشه ممنون میشم  ، کارم گیر کرده ♥:53:
در 21 ساعت قبل، hosseinkarimian گفته است :
دوستان کارم گیره کمک کنید ممنون میشم
