مشکل در استفاده از فرگمنت
akftes
با سلام و احترام
من یک کلاس از نوع فرگمنت ایجاد کردم به صورت زیر
package com.example.criminalintent;
import android.os.Bundle;
import android.text.Editable;
import android.text.TextWatcher;
import android.text.style.TtsSpan;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.widget.Button;
import android.widget.CheckBox;
import android.widget.CompoundButton;
import android.widget.EditText;
import androidx.annotation.NonNull;
import androidx.annotation.Nullable;
import androidx.fragment.app.Fragment;
public class CrimeFragment extends Fragment {
private  Crime mCrime;
private EditText mTitleField;
private Button mDateButton;
private CheckBox mSolvedChechBox;
    @Override
    public void onCreate(@Nullable Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        mCrime=new Crime();
    @Nullable
    @Override
    public View onCreateView(@NonNull LayoutInflater inflater, @Nullable ViewGroup container, @Nullable Bundle savedInstanceState) {
        //return super.onCreateView(inflater, container, savedInstanceState);
        View v = inflater.inflate(R.layout.fragment_crime,container,false);
        mTitleField=(EditText) v.findViewById(R.id.crime_tittle);
        mTitleField.addTextChangedListener(new TextWatcher() {
            @Override
            public void beforeTextChanged(CharSequence s, int start, int count, int after) {
            @Override
            public void onTextChanged(CharSequence s, int start, int before, int count) {
                mCrime.setmTitle(s.toString());
            @Override
            public void afterTextChanged(Editable s) {
        mDateButton=(Button) v.findViewById(R.id.crime_date) ;
        mDateButton.setText(mCrime.getmDate().toString());
        mDateButton.setEnabled(false);
        mSolvedChechBox=(CheckBox) v.findViewById(R.id.crime_solved);
        mSolvedChechBox.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
            @Override
            public void onCheckedChanged(CompoundButton buttonView, boolean isChecked) {
                mCrime.setmSolved(isChecked);
        return v;
داخل MainActivity هم بصورت زیر یک  Fragment transactions ایجاد کردم :
public class MainActivity extends AppCompatActivity {
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.activity_main);
        FragmentManager fm = new AppCompatActivity().getSupportFragmentManager();
        Fragment fragment = fm.findFragmentById(R.id.fragmen_container);
        if(fragment==null){
            fragment= new CrimeFragment();
            fm.beginTransaction().add(R.id.fragmen_container,fragment).commit();
ولی موقع اجرا اکتیویتی از صفحه میپره و  از برنامه میاد بیرون .
لاگ کت هم بصورت زیر خروجی میده
2020-06-04 13:30:41.819 31140-31140/? E/AndroidRuntime: FATAL EXCEPTION: main
    Process: com.example.criminalintent, PID: 31140
    java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.criminalintent/com.example.criminalintent.MainActivity}: java.lang.IllegalStateException: Activity has been destroyed
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3303)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3411)
        at android.app.ActivityThread.-wrap12(Unknown Source:0)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1994)
        at android.os.Handler.dispatchMessage(Handler.java:108)
        at android.os.Looper.loop(Looper.java:166)
        at android.app.ActivityThread.main(ActivityThread.java:7529)
        at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:245)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:921)
     Caused by: java.lang.IllegalStateException: Activity has been destroyed
        at androidx.fragment.app.FragmentManagerImpl.enqueueAction(FragmentManager.java:2114)
        at androidx.fragment.app.BackStackRecord.commitInternal(BackStackRecord.java:683)
        at androidx.fragment.app.BackStackRecord.commit(BackStackRecord.java:637)
        at com.example.criminalintent.MainActivity.onCreate(MainActivity.java:27)
        at android.app.Activity.performCreate(Activity.java:7383)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1218)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3256)
2020-06-04 13:30:41.859 31140-31140/? I/Process: Sending signal. PID: 31140 SIG: 9
ممنون میشم کمک کنید .
در در 15 خرداد 1399 در 15:03، akftes گفته است :
چطور توی کتاب Android Programming_ The Big Nerd Ranch Guide  همونطوری که من نوشتم گفته
کتابی که گفتید ماله 2012 هستش - 8 سال قبل!
کتاب های جدید و دوره های آموزشی جدید زیاده داخل اینترنت
پیشنهاد میکنم بیخیال اون کتاب بشید که احتمال زیاد 90 درصد محتواش دیگه به درد نمیخوره
و اما دلیل کرش کردن اپلیکیشن این خط هستش:
که باید بشه:
FragmentManager fm = getSupportFragmentManager();
و هیچ نیازی به این خط کد نیست:
چون شما داخل متد onCreate این کدهارو اجرا میکنید تنها یک بار در طول حیات اکتیویتی این کد اجرا میشه
و بعد از add کردن فرگمنت باید با show نشونش بدید
پیشنهاد میکنم بیخیال این روش بشید و روش معقول تر replace که جناب شاهپیری گفتن رو استفاده کنید. بهینه تر و ساده تر بخاطر method chaining
در 56 دقیقه قبل، akftes گفته است :
توی کلاس CrimeFragment یک instance به شکل زیر بسازید. در واقع متد زیر رو اضافه کنید
public static CrimeFragment instance(){
  return new CrimeFragment();
تو اکتیویتی هم که باید به شکل زیر فرگمنت رو لود کنید
    @Override
    	getSupportFragmentManager().beginTransaction().replace(R.id.fragmen_container,CrimeFragment.instance()).commit();
در 19 دقیقه قبل، محمدرضا شاهپیری گفته است :
    @Override
