Mr.Kafiri 221 ارسال شده در 4 شهریور، 2020 اشتراک گذاری ارسال شده در 4 شهریور، 2020 سلام دوستان بالاخره ورژن 9.90 بسیک امروز صبح حاج ارل منتشر کردن البته نسخه بتا هست هنوز پیشرفت ها: Add new module - Option to add the new module to the parent folder. This is useful in cross platform projects where the modules are shared between the different platforms. Fix for a design issue that existed since B4A v1.0 where in some cases assignment of an object to a variable can also change other variables that point to the same "wrapper". New warning: "Comparison of Object to other types will fail if exact types do not match. Better to put the object on the right side of the comparison. (warning #35)" See this post for more information: https://www.b4x.com/android/forum/t...-is-available-for-download.117877/post-737515. Support for Java 14 (must use the one downloaded from B4X). Fix for empty description windows in some cases. Several debugger fixes. New "contribute" menu item. Current selected line, in the search results and other syntax colored lists, is displayed. B4XTurtle and BCTextEngine are now internal libraries. Network v1.52 - UDPSocket.GetBroadcastAddress method. The code editor cursor color can be changed in the INI file. It uses the same 0xAABBGGRR format as in the theme files (CursorColor=0x000000FF). Template of XUI custom views was updated. The convention explained here is implemented: https://www.b4x.com/android/forum/threads/117992/#content Fix for compilation error when compiling projects with many modules. Latest versions of all internal libraries are included. Other bug fixes and minor IDE improvements پست اصلی: https://www.b4x.com/android/forum/threads/b4a-v9-90-beta-is-available-for-download.118628/ لینک دانلود: www.b4x.com/android/files/beta.exe لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
