امروز با یه خطای ناشناخته هنگام کامپایل برنامم روبرو شدم که هرکاری میکنم برطرف نمیشه.
البته مربوط به پروژم نیست چون روی هر پروژه ای این خطا رو میده:
B4A Version: 10.0
Java Version: 8
Parsing code. (0.00s)
Building folders structure. (0.10s)
Compiling code. (0.28s)
Compiling layouts code. (0.03s)
Organizing libraries. (0.00s)
(Android Support Library)
Generating R file. (0.00s)
Compiling generated Java code. Error
Error occurred during initialization of VM
Could not reserve enough space for 2097152KB object heap
snoorana 13
B4A Version: 10.0 Java Version: 8 Parsing code. (0.00s) Building folders structure. (0.10s) Compiling code. (0.28s) Compiling layouts code. (0.03s) Organizing libraries. (0.00s) (Android Support Library) Generating R file. (0.00s) Compiling generated Java code. Error Error occurred during initialization of VM Could not reserve enough space for 2097152KB object heapممنون میشم کمکم کنید
