من دارم رو یه پروژه کار میکنم وقتی میخوام انیمیشن های لاتی رو پروژم پیاده کنم موقع اجرا برنامه کرش میکنه و میگه
Logger connected to: LGE LG-K430
--------- beginning of crash
--------- beginning of main
*** Service (starter) Create ***
** Service (starter) Start **
** Activity (main) Resume **
lib:Raising.. on_oncompositionloaded()
--------- beginning of system
java.lang.IndexOutOfBoundsException: Invalid index 0, size is 0
at java.util.ArrayList.throwIndexOutOfBoundsException(ArrayList.java:255)
at java.util.ArrayList.get(ArrayList.java:308)
at com.airbnb.lottie.animation.ScaleKeyframeAnimation.getValue(ScaleKeyframeAnimation.java:41)
at com.airbnb.lottie.animation.ScaleKeyframeAnimation.getValue(ScaleKeyframeAnimation.java:13)
at com.airbnb.lottie.animation.KeyframeAnimation.setProgress(KeyframeAnimation.java:75)
at com.airbnb.lottie.layers.AnimatableLayer.setProgress(AnimatableLayer.java:255)
at com.airbnb.lottie.layers.LayerView.setProgress(LayerView.java:281)
at com.airbnb.lottie.layers.AnimatableLayer.setProgress(AnimatableLayer.java:259)
at com.airbnb.lottie.layers.LottieDrawable$1.onAnimationUpdate(LottieDrawable.java:50)
at android.animation.ValueAnimator.animateValue(ValueAnimator.java:1463)
at android.animation.ValueAnimator.animationFrame(ValueAnimator.java:1384)
at android.animation.ValueAnimator.doAnimationFrame(ValueAnimator.java:1427)
at android.animation.ValueAnimator$AnimationHandler.doAnimationFrame(ValueAnimator.java:759)
at android.animation.ValueAnimator$AnimationHandler$1.run(ValueAnimator.java:801)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:858)
at android.view.Choreographer.doCallbacks(Choreographer.java:670)
at android.view.Choreographer.doFrame(Choreographer.java:603)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:844)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5530)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:734)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:624)
Mahdi83 2
Logger connected to: LGE LG-K430 --------- beginning of crash --------- beginning of main *** Service (starter) Create *** ** Service (starter) Start ** ** Activity (main) Create, isFirst = true ** ** Activity (main) Resume ** lib:Raising.. on_oncompositionloaded() --------- beginning of system java.lang.IndexOutOfBoundsException: Invalid index 0, size is 0 at java.util.ArrayList.throwIndexOutOfBoundsException(ArrayList.java:255) at java.util.ArrayList.get(ArrayList.java:308) at com.airbnb.lottie.animation.ScaleKeyframeAnimation.getValue(ScaleKeyframeAnimation.java:41) at com.airbnb.lottie.animation.ScaleKeyframeAnimation.getValue(ScaleKeyframeAnimation.java:13) at com.airbnb.lottie.animation.KeyframeAnimation.setProgress(KeyframeAnimation.java:75) at com.airbnb.lottie.layers.AnimatableLayer.setProgress(AnimatableLayer.java:255) at com.airbnb.lottie.layers.LayerView.setProgress(LayerView.java:281) at com.airbnb.lottie.layers.AnimatableLayer.setProgress(AnimatableLayer.java:259) at com.airbnb.lottie.layers.LottieDrawable$1.onAnimationUpdate(LottieDrawable.java:50) at android.animation.ValueAnimator.animateValue(ValueAnimator.java:1463) at android.animation.ValueAnimator.animationFrame(ValueAnimator.java:1384) at android.animation.ValueAnimator.doAnimationFrame(ValueAnimator.java:1427) at android.animation.ValueAnimator$AnimationHandler.doAnimationFrame(ValueAnimator.java:759) at android.animation.ValueAnimator$AnimationHandler$1.run(ValueAnimator.java:801) at android.view.Choreographer$CallbackRecord.run(Choreographer.java:858) at android.view.Choreographer.doCallbacks(Choreographer.java:670) at android.view.Choreographer.doFrame(Choreographer.java:603) at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:844) at android.os.Handler.handleCallback(Handler.java:739) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:148) at android.app.ActivityThread.main(ActivityThread.java:5530) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:734) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:624)کسی براش راه حل داره
ورژن appcompact هم 3.52 هست
