اقا من موقعی که کتابخونه اقای شاهپری که پرشین پکیج منیجر هست رو اد می کنم به پروژه با پکیج "COM.ANTI" خطا زیر می ده هیچ راهی نداره من پکیج رو تغییر ندم و از این کتابخونه استفاده کنم
PARSE ERROR:
class name (com/packagemanager/R) does not match path (COM/packagemanager/R.class)
...while parsing COM/packagemanager/R.class
PARSE ERROR:
class name (com/packagemanager/R$attr) does not match path (COM/packagemanager/R$attr.class)
...while parsing COM/packagemanager/R$attr.class
PARSE ERROR:
class name (com/packagemanager/R$color) does not match path (COM/packagemanager/R$color.class)
...while parsing COM/packagemanager/R$color.class
PARSE ERROR:
class name (com/packagemanager/R$dimen) does not match path (COM/packagemanager/R$dimen.class)
...while parsing COM/packagemanager/R$dimen.class
PARSE ERROR:
class name (com/packagemanager/R$drawable) does not match path (COM/packagemanager/R$drawable.class)
...while parsing COM/packagemanager/R$drawable.class
PARSE ERROR:
class name (com/packagemanager/R$id) does not match path (COM/packagemanager/R$id.class)
...while parsing COM/packagemanager/R$id.class
PARSE ERROR:
class name (com/packagemanager/R$integer) does not match path (COM/packagemanager/R$integer.class)
...while parsing COM/packagemanager/R$integer.class
PARSE ERROR:
class name (com/packagemanager/R$layout) does not match path (COM/packagemanager/R$layout.class)
...while parsing COM/packagemanager/R$layout.class
PARSE ERROR:
class name (com/packagemanager/R$string) does not match path (COM/packagemanager/R$string.class)
...while parsing COM/packagemanager/R$string.class
PARSE ERROR:
class name (com/packagemanager/R$style) does not match path (COM/packagemanager/R$style.class)
...while parsing COM/packagemanager/R$style.class
PARSE ERROR:
class name (com/packagemanager/R$styleable) does not match path (COM/packagemanager/R$styleable.class)
...while parsing COM/packagemanager/R$styleable.class
PARSE ERROR:
class name (com/packagemanager/R$xml) does not match path (COM/packagemanager/R$xml.class)
...while parsing COM/packagemanager/R$xml.class
12 errors; aborting
ali mo 264
سلام وقت بخیر
PARSE ERROR: class name (com/packagemanager/R) does not match path (COM/packagemanager/R.class) ...while parsing COM/packagemanager/R.class PARSE ERROR: class name (com/packagemanager/R$attr) does not match path (COM/packagemanager/R$attr.class) ...while parsing COM/packagemanager/R$attr.class PARSE ERROR: class name (com/packagemanager/R$color) does not match path (COM/packagemanager/R$color.class) ...while parsing COM/packagemanager/R$color.class PARSE ERROR: class name (com/packagemanager/R$dimen) does not match path (COM/packagemanager/R$dimen.class) ...while parsing COM/packagemanager/R$dimen.class PARSE ERROR: class name (com/packagemanager/R$drawable) does not match path (COM/packagemanager/R$drawable.class) ...while parsing COM/packagemanager/R$drawable.class PARSE ERROR: class name (com/packagemanager/R$id) does not match path (COM/packagemanager/R$id.class) ...while parsing COM/packagemanager/R$id.class PARSE ERROR: class name (com/packagemanager/R$integer) does not match path (COM/packagemanager/R$integer.class) ...while parsing COM/packagemanager/R$integer.class PARSE ERROR: class name (com/packagemanager/R$layout) does not match path (COM/packagemanager/R$layout.class) ...while parsing COM/packagemanager/R$layout.class PARSE ERROR: class name (com/packagemanager/R$string) does not match path (COM/packagemanager/R$string.class) ...while parsing COM/packagemanager/R$string.class PARSE ERROR: class name (com/packagemanager/R$style) does not match path (COM/packagemanager/R$style.class) ...while parsing COM/packagemanager/R$style.class PARSE ERROR: class name (com/packagemanager/R$styleable) does not match path (COM/packagemanager/R$styleable.class) ...while parsing COM/packagemanager/R$styleable.class PARSE ERROR: class name (com/packagemanager/R$xml) does not match path (COM/packagemanager/R$xml.class) ...while parsing COM/packagemanager/R$xml.class 12 errors; abortingلینک ارسال
