سلام برای اتصال به درون پرداخت بازارهای کافه بازار و مایکت با ارور زیر مواجه میشوم. لطفا راهنمایی بفرماید.
نسخه جاوا: jdk-11.0.1
--------- beginning of main
*** Service (starter) Create ***
** Service (starter) Start **
main_activity_create (java line: 361)
java.lang.NullPointerException: Attempt to invoke interface method 'boolean java.util.List.isEmpty()' on a null object reference
at anywheresoftware.b4a.objects.IbHelper.startSetup(IbHelper.java:165)
at anywheresoftware.b4a.inappbilling3.BillingManager3.Initialize(BillingManager3.java:32)
at b4a.example.englishtest.main._activity_create(main.java:361)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:213)
at b4a.example.englishtest.main.afterFirstLayout(main.java:105)
at b4a.example.englishtest.main.access$000(main.java:17)
at b4a.example.englishtest.main$WaitForLayout.run(main.java:83)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5585)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:730)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:620)
mohsen m 156
... --------- beginning of main *** Service (starter) Create *** ** Service (starter) Start ** ** Activity (main) Create, isFirst = true ** main_activity_create (java line: 361) java.lang.NullPointerException: Attempt to invoke interface method 'boolean java.util.List.isEmpty()' on a null object reference at anywheresoftware.b4a.objects.IbHelper.startSetup(IbHelper.java:165) at anywheresoftware.b4a.inappbilling3.BillingManager3.Initialize(BillingManager3.java:32) at b4a.example.englishtest.main._activity_create(main.java:361) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:213) at b4a.example.englishtest.main.afterFirstLayout(main.java:105) at b4a.example.englishtest.main.access$000(main.java:17) at b4a.example.englishtest.main$WaitForLayout.run(main.java:83) at android.os.Handler.handleCallback(Handler.java:739) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:148) at android.app.ActivityThread.main(ActivityThread.java:5585) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:730) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:620)لینک ارسال
