cl.Initialize(Colors.RGB(241,134,34),50dip)
voice_fa.Initialize("voice_fa")
voice_en.Initialize("voice_en")
lst_menu.Initialize("")
pnl_save_del.Color=Colors.RGB(184,221,154)
img_copy.Visible=False
Activity.Color=Colors.White
pnl_sep.Background=cl
ahn.Initialize2("ahn",Activity,75%x,ahn.GRAVITY_LEFT)
ahn.ContentPanel.LoadLayout("main_page")
ahn.NavigationPanel.LoadLayout("Menu")
pnl_header.Color=Colors.RGB(0,35,149)
lbl_header.Text="صفحه اصلی"
lbl_header.TextColor=Colors.White
lbl_header.TextSize=15
lbl_header.Typeface=Typeface.LoadFromAssets("bold.ttf")
lst_menu.AddTwoLinesAndBitmap("درباره ما","",LoadBitmap(File.DirAssets,"i.png"))
lst_menu.AddTwoLinesAndBitmap("متن ها","",LoadBitmap(File.DirAssets,"db.png"))
lst_menu.TwoLinesAndBitmap.Label.TextColor=Colors.Black
lst_menu.TwoLinesAndBitmap.Label.Gravity=Gravity.LEFT
lst_menu.Color=Colors.RGB(184,221,154)
lst_menu.TwoLinesAndBitmap.Label.TextSize=14
lst_menu.TwoLinesAndBitmap.Label.Typeface=Typeface.LoadFromAssets("bold.ttf")
lst_menu.TwoLinesAndBitmap.ItemHeight=lst_menu.TwoLinesAndBitmap.ImageView.Height+1%y
tap.initialize("lkrqgtkodietaqqibiricsshcqclmbtshbdlrollbtkabjgodbecicgaaenfrsqtsrhbhr")
tap.fillBannerAd(pnl_adv,"5ff5936c63de180001edc7bb",tap.BANNER_320x50)
If File.Exists(File.DirRootExternal,"voice to text")=False Then
File.MakeDir(File.DirRootExternal,"voice to text")
If File.Exists(File.DirRootExternal&"/voice to text","db.db")=False Then
File.Copy(File.DirAssets,"db.db",File.DirRootExternal&"/voice to text","db.db")
If sql.IsInitialized=False Then
sql.Initialize(File.DirRootExternal&"/voice to text","db.db",True)
lbl_header.Height=su.MeasureMultilineTextHeight(lbl_header,lbl_header.Text)
SetDivider(lst_menu,Colors.Black,0.2%y)
توی همه اندروید ها به جز اندروید 10 کدها بدون خطا اجرا میشن اما توی اندروید 10 همین دستورات فورس کلوز میدن!!
MR.B4A 220
سلام.
دوستان این دستورات activity_create منه:
cl.Initialize(Colors.RGB(241,134,34),50dip) voice_fa.Initialize("voice_fa") voice_en.Initialize("voice_en") lst_menu.Initialize("") pnl_save_del.Color=Colors.RGB(184,221,154) img_copy.Visible=False Activity.Color=Colors.White pnl_sep.Background=cl ahn.Initialize2("ahn",Activity,75%x,ahn.GRAVITY_LEFT) ahn.ContentPanel.LoadLayout("main_page") ahn.NavigationPanel.LoadLayout("Menu") pnl_header.Color=Colors.RGB(0,35,149) lbl_header.Text="صفحه اصلی" lbl_header.TextColor=Colors.White lbl_header.TextSize=15 lbl_header.Typeface=Typeface.LoadFromAssets("bold.ttf") lst_menu.AddTwoLinesAndBitmap("درباره ما","",LoadBitmap(File.DirAssets,"i.png")) lst_menu.AddTwoLinesAndBitmap("متن ها","",LoadBitmap(File.DirAssets,"db.png")) lst_menu.TwoLinesAndBitmap.Label.TextColor=Colors.Black lst_menu.TwoLinesAndBitmap.Label.Gravity=Gravity.LEFT lst_menu.Color=Colors.RGB(184,221,154) lst_menu.TwoLinesAndBitmap.Label.TextSize=14 lst_menu.TwoLinesAndBitmap.Label.Typeface=Typeface.LoadFromAssets("bold.ttf") lst_menu.TwoLinesAndBitmap.ItemHeight=lst_menu.TwoLinesAndBitmap.ImageView.Height+1%y tap.initialize("lkrqgtkodietaqqibiricsshcqclmbtshbdlrollbtkabjgodbecicgaaenfrsqtsrhbhr") tap.fillBannerAd(pnl_adv,"5ff5936c63de180001edc7bb",tap.BANNER_320x50) If File.Exists(File.DirRootExternal,"voice to text")=False Then File.MakeDir(File.DirRootExternal,"voice to text") End If If File.Exists(File.DirRootExternal&"/voice to text","db.db")=False Then File.Copy(File.DirAssets,"db.db",File.DirRootExternal&"/voice to text","db.db") End If If sql.IsInitialized=False Then sql.Initialize(File.DirRootExternal&"/voice to text","db.db",True) End If lbl_header.Height=su.MeasureMultilineTextHeight(lbl_header,lbl_header.Text) SetDivider(lst_menu,Colors.Black,0.2%y)توی همه اندروید ها به جز اندروید 10 کدها بدون خطا اجرا میشن اما توی اندروید 10 همین دستورات فورس کلوز میدن!!
من هرکاری کردم درست نشد.
ممنون میشم راهنماییم کنید.
