cl.Initialize(Colors.RGB(241,134,34),50dip)
voice_fa.Initialize("voice_fa")
voice_en.Initialize("voice_en")
lst_menu.Initialize("")
pnl_save_del.Color=Colors.RGB(184,221,154)
img_copy.Visible=False
Activity.Color=Colors.White
pnl_sep.Background=cl
ahn.Initialize2("ahn",Activity,75%x,ahn.GRAVITY_LEFT)
ahn.ContentPanel.LoadLayout("main_page")
ahn.NavigationPanel.LoadLayout("Menu")
pnl_header.Color=Colors.RGB(0,35,149)
lbl_header.Text="صفحه اصلی"
lbl_header.TextColor=Colors.White
lbl_header.TextSize=15
lbl_header.Typeface=Typeface.LoadFromAssets("bold.ttf")
lst_menu.AddTwoLinesAndBitmap("درباره ما","",LoadBitmap(File.DirAssets,"i.png"))
lst_menu.AddTwoLinesAndBitmap("متن ها","",LoadBitmap(File.DirAssets,"db.png"))
lst_menu.TwoLinesAndBitmap.Label.TextColor=Colors.Black
lst_menu.TwoLinesAndBitmap.Label.Gravity=Gravity.LEFT
lst_menu.Color=Colors.RGB(184,221,154)
lst_menu.TwoLinesAndBitmap.Label.TextSize=14
lst_menu.TwoLinesAndBitmap.Label.Typeface=Typeface.LoadFromAssets("bold.ttf")
lst_menu.TwoLinesAndBitmap.ItemHeight=lst_menu.TwoLinesAndBitmap.ImageView.Height+1%y
tap.initialize("lkrqgtkodietaqqibiricsshcqclmbtshbdlrollbtkabjgodbecicgaaenfrsqtsrhbhr")
tap.fillBannerAd(pnl_adv,"5ff5936c63de180001edc7bb",tap.BANNER_320x50)
If File.Exists(File.DirRootExternal,"voice to text")=False Then
File.MakeDir(File.DirRootExternal,"voice to text")
If File.Exists(File.DirRootExternal&"/voice to text","db.db")=False Then
File.Copy(File.DirAssets,"db.db",File.DirRootExternal&"/voice to text","db.db")
If sql.IsInitialized=False Then
sql.Initialize(File.DirRootExternal&"/voice to text","db.db",True)
lbl_header.Height=su.MeasureMultilineTextHeight(lbl_header,lbl_header.Text)
SetDivider(lst_menu,Colors.Black,0.2%y)
توی همه اندروید ها به جز اندروید 10 کدها بدون خطا اجرا میشن اما توی اندروید 10 همین دستورات فورس کلوز میدن!!
MR.B4A 104
سلام.
دوستان این دستورات activity_create منه:
cl.Initialize(Colors.RGB(241,134,34),50dip) voice_fa.Initialize("voice_fa") voice_en.Initialize("voice_en") lst_menu.Initialize("") pnl_save_del.Color=Colors.RGB(184,221,154) img_copy.Visible=False Activity.Color=Colors.White pnl_sep.Background=cl ahn.Initialize2("ahn",Activity,75%x,ahn.GRAVITY_LEFT) ahn.ContentPanel.LoadLayout("main_page") ahn.NavigationPanel.LoadLayout("Menu") pnl_header.Color=Colors.RGB(0,35,149) lbl_header.Text="صفحه اصلی" lbl_header.TextColor=Colors.White lbl_header.TextSize=15 lbl_header.Typeface=Typeface.LoadFromAssets("bold.ttf") lst_menu.AddTwoLinesAndBitmap("درباره ما","",LoadBitmap(File.DirAssets,"i.png")) lst_menu.AddTwoLinesAndBitmap("متن ها","",LoadBitmap(File.DirAssets,"db.png")) lst_menu.TwoLinesAndBitmap.Label.TextColor=Colors.Black lst_menu.TwoLinesAndBitmap.Label.Gravity=Gravity.LEFT lst_menu.Color=Colors.RGB(184,221,154) lst_menu.TwoLinesAndBitmap.Label.TextSize=14 lst_menu.TwoLinesAndBitmap.Label.Typeface=Typeface.LoadFromAssets("bold.ttf") lst_menu.TwoLinesAndBitmap.ItemHeight=lst_menu.TwoLinesAndBitmap.ImageView.Height+1%y tap.initialize("lkrqgtkodietaqqibiricsshcqclmbtshbdlrollbtkabjgodbecicgaaenfrsqtsrhbhr") tap.fillBannerAd(pnl_adv,"5ff5936c63de180001edc7bb",tap.BANNER_320x50) If File.Exists(File.DirRootExternal,"voice to text")=False Then File.MakeDir(File.DirRootExternal,"voice to text") End If If File.Exists(File.DirRootExternal&"/voice to text","db.db")=False Then File.Copy(File.DirAssets,"db.db",File.DirRootExternal&"/voice to text","db.db") End If If sql.IsInitialized=False Then sql.Initialize(File.DirRootExternal&"/voice to text","db.db",True) End If lbl_header.Height=su.MeasureMultilineTextHeight(lbl_header,lbl_header.Text) SetDivider(lst_menu,Colors.Black,0.2%y)
من هرکاری کردم درست نشد.
ممنون میشم راهنماییم کنید.
