سلام من کدهای زیر رو در برنامه قرار دادم اما از کاربر دسترسی درخواست نمیکنه.
کدهای منیفست رو هم اضافه کردم
روی اندروید 9 و 10 تست کردم
Activity.LoadLayout("main")
If Not(rr.Check(rr.PERMISSION_READ_SMS)) Then
Wait For Msgbox_Result (Result As Int)
rr.CheckAndRequest(rr.PERMISSION_READ_SMS)
Wait For activity_PermissionResult (Permission As String, havePermission As Boolean)
If havePermission = False Then
Return
If Not(rr.Check(rr.PERMISSION_RECEIVE_SMS)) Then
rr.CheckAndRequest(rr.PERMISSION_RECEIVE_SMS)
Return
If Not(rr.Check(rr.PERMISSION_READ_CONTACTS)) Then
rr.CheckAndRequest(rr.PERMISSION_READ_CONTACTS)
Return
If Not(rr.Check(rr.PERMISSION_READ_CALL_LOG)) Then
rr.CheckAndRequest(rr.PERMISSION_READ_CALL_LOG)
Return
mostafaHD 44
Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("main") If Not(rr.Check(rr.PERMISSION_READ_SMS)) Then Wait For Msgbox_Result (Result As Int) rr.CheckAndRequest(rr.PERMISSION_READ_SMS) Wait For activity_PermissionResult (Permission As String, havePermission As Boolean) If havePermission = False Then Return End If End If If Not(rr.Check(rr.PERMISSION_RECEIVE_SMS)) Then Wait For Msgbox_Result (Result As Int) rr.CheckAndRequest(rr.PERMISSION_RECEIVE_SMS) Wait For activity_PermissionResult (Permission As String, havePermission As Boolean) If havePermission = False Then Return End If End If If Not(rr.Check(rr.PERMISSION_READ_CONTACTS)) Then Wait For Msgbox_Result (Result As Int) rr.CheckAndRequest(rr.PERMISSION_READ_CONTACTS) Wait For activity_PermissionResult (Permission As String, havePermission As Boolean) If havePermission = False Then Return End If End If If Not(rr.Check(rr.PERMISSION_READ_CALL_LOG)) Then Wait For Msgbox_Result (Result As Int) rr.CheckAndRequest(rr.PERMISSION_READ_CALL_LOG) Wait For activity_PermissionResult (Permission As String, havePermission As Boolean) If havePermission = False Then Return End If End If End Sub
