در زمان خروجی گرفتن نهایی با خطای زیر مواجه میشم لطفا راهنمایی نمایید تا مشکلم حل شود. ممنون
B4A Version: 8.00
Parsing code. (0.01s)
Compiling code. (0.29s)
Compiling layouts code. (0.08s)
Organizing libraries. (0.00s)
Generating R file. Error
ERROR: Unknown option '--auto-add-overlay'
Android Asset Packaging Tool
Usage:
aapt l[ist] [-v] [-a] file.{zip,jar,apk}
List contents of Zip-compatible archive.
aapt d[ump] [--values] WHAT file.{apk} [asset [asset ...]]
badging Print the label and icon for the app declared in APK.
permissions Print the permissions from the APK.
resources Print the resource table from the APK.
configurations Print the configurations in the APK.
xmltree Print the compiled xmls in the given assets.
xmlstrings Print the strings of the given compiled xml assets.
aapt p[ackage] [-d][-f][-m][-u][-v][-x][-z][-M AndroidManifest.xml] \
[-0 extension [-0 extension ...]] [-g tolerance] [-j jarfile] \
[--min-sdk-version VAL] [--target-sdk-version VAL] \
[--max-sdk-version VAL] [--app-version VAL] \
[--app-version-name TEXT]\
[-I base-package [-I base-package ...]] \
[-A asset-source-dir] [-G class-list-file] [-P public-definitions-file] \
[-S resource-sources [-S resource-sources ...]] [-F apk-file] [-J R-file-dir] \
[raw-files-dir [raw-files-dir] ...]
Package the android resources. It will read assets and resources that are
supplied with the -M -A -S or raw-files-dir arguments. The -J -P -F and -R
options control which files are output.
aapt r[emove] [-v] file.{zip,jar,apk} file1 [file2 ...]
Delete specified files from Zip-compatible archive.
aapt a[dd] [-v] file.{zip,jar,apk} file1 [file2 ...]
Add specified files to Zip-compatible archive.
aapt v[ersion]
Print program version.
Modifiers:
-a print Android-specific data (resources, manifest) when listing
-c specify which configurations to include. The default is all
configurations. The value of the parameter should be a comma
separated list of configuration values. Locales should be specified
as either a language or language-region pair. Some examples:
en
port,en
port,land,en_US
If you put the special locale, zz_ZZ on the list, it will perform
pseudolocalization on the default locale, modifying all of the
strings so you can look for strings that missed the
internationalization process. For example:
port,land,zz_ZZ
-d one or more device assets to include, separated by commas
-f force overwrite of existing files
-g specify a pixel tolerance to force images to grayscale, default 0
-j specify a jar or zip file containing classes to include
-m make package directories under location specified by -J
-u update existing packages (add new, replace older, remove deleted files)
-v verbose output
-x create extending (non-application) resource IDs
-z require localization of resource attributes marked with
localization="suggested"
-A additional directory in which to find raw asset files
-G A file to output proguard options into.
-F specify the apk file to output
-I add an existing package to base include set
-J specify where to output R.java resource constant definitions
-M specify full path to AndroidManifest.xml to include in zip
-P specify where to output public resource definitions
-S directory in which to find resources. Multiple directories will be scanned and the first match found (left to right) will take precedence. -0 specifies an additional extension for which such files will not
be stored compressed in the .apk. An empty string means to not
compress any files at all.
--min-sdk-version
inserts android:minSdkVersion in to manifest.
inserts android:targetSdkVersion in to manifest.
--max-sdk-version
inserts android:maxSdkVersion in to manifest.
--values
when used with "dump resources" also includes resource values.
--version-code
inserts android:versionCode in to manifest.
--version-name
inserts android:versionName in to manifest.
shahab07 0
با سلام وعرض ادب خدمت استادان عزیز
B4A Version: 8.00 Parsing code. (0.01s) Compiling code. (0.29s) Compiling layouts code. (0.08s) Organizing libraries. (0.00s) Generating R file. Error ERROR: Unknown option '--auto-add-overlay' Android Asset Packaging Tool Usage: aapt l[ist] [-v] [-a] file.{zip,jar,apk} List contents of Zip-compatible archive. aapt d[ump] [--values] WHAT file.{apk} [asset [asset ...]] badging Print the label and icon for the app declared in APK. permissions Print the permissions from the APK. resources Print the resource table from the APK. configurations Print the configurations in the APK. xmltree Print the compiled xmls in the given assets. xmlstrings Print the strings of the given compiled xml assets. aapt p[ackage] [-d][-f][-m][-u][-v][-x][-z][-M AndroidManifest.xml] \ [-0 extension [-0 extension ...]] [-g tolerance] [-j jarfile] \ [--min-sdk-version VAL] [--target-sdk-version VAL] \ [--max-sdk-version VAL] [--app-version VAL] \ [--app-version-name TEXT]\ [-I base-package [-I base-package ...]] \ [-A asset-source-dir] [-G class-list-file] [-P public-definitions-file] \ [-S resource-sources [-S resource-sources ...]] [-F apk-file] [-J R-file-dir] \ [raw-files-dir [raw-files-dir] ...] Package the android resources. It will read assets and resources that are supplied with the -M -A -S or raw-files-dir arguments. The -J -P -F and -R options control which files are output. aapt r[emove] [-v] file.{zip,jar,apk} file1 [file2 ...] Delete specified files from Zip-compatible archive. aapt a[dd] [-v] file.{zip,jar,apk} file1 [file2 ...] Add specified files to Zip-compatible archive. aapt v[ersion] Print program version. Modifiers: -a print Android-specific data (resources, manifest) when listing -c specify which configurations to include. The default is all configurations. The value of the parameter should be a comma separated list of configuration values. Locales should be specified as either a language or language-region pair. Some examples: en port,en port,land,en_US If you put the special locale, zz_ZZ on the list, it will perform pseudolocalization on the default locale, modifying all of the strings so you can look for strings that missed the internationalization process. For example: port,land,zz_ZZ -d one or more device assets to include, separated by commas -f force overwrite of existing files -g specify a pixel tolerance to force images to grayscale, default 0 -j specify a jar or zip file containing classes to include -m make package directories under location specified by -J -u update existing packages (add new, replace older, remove deleted files) -v verbose output -x create extending (non-application) resource IDs -z require localization of resource attributes marked with localization="suggested" -A additional directory in which to find raw asset files -G A file to output proguard options into. -F specify the apk file to output -I add an existing package to base include set -J specify where to output R.java resource constant definitions -M specify full path to AndroidManifest.xml to include in zip -P specify where to output public resource definitions -S directory in which to find resources. Multiple directories will be scanned and the first match found (left to right) will take precedence. -0 specifies an additional extension for which such files will not be stored compressed in the .apk. An empty string means to not compress any files at all. --min-sdk-version inserts android:minSdkVersion in to manifest. --target-sdk-version inserts android:targetSdkVersion in to manifest. --max-sdk-version inserts android:maxSdkVersion in to manifest. --values when used with "dump resources" also includes resource values. --version-code inserts android:versionCode in to manifest. --version-name inserts android:versionName in to manifest.لینک ارسال
