وقتی روی دکمه برنامه کلیک می کنم تا از دیتابیس آنلاین اطلاعاتو بخونه یه ارری میده
خواهش میکنم راهنماییم کنید ایراد کار از کجاست
ممنونم
خط 141 که محل ارر هست اینه
list=jp1.NextArray
** Activity (frm_news_slv) Resume **
Panel size is unknown. Layout may not be loaded correctly.
Error occurred on line: 141 (frm_news_slv)
org.json.JSONException: End of input at character 2 of
at org.json.JSONTokener.syntaxError(JSONTokener.java:450)
at org.json.JSONTokener.nextValue(JSONTokener.java:97)
at anywheresoftware.b4a.objects.collections.JSONParser.NextArray(JSONParser.java:60)
at java.lang.reflect.Method.invoke(Method.java:372)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
at anywheresoftware.b4a.BA$2.run(BA.java:370)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5254)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:905)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:700)
hamedafrough 5
سلام به همه اساتید
ممنونم
list=jp1.NextArray
** Activity (frm_news_slv) Resume ** Panel size is unknown. Layout may not be loaded correctly. Panel size is unknown. Layout may not be loaded correctly. Panel size is unknown. Layout may not be loaded correctly. Panel size is unknown. Layout may not be loaded correctly. Panel size is unknown. Layout may not be loaded correctly. Error occurred on line: 141 (frm_news_slv) org.json.JSONException: End of input at character 2 of at org.json.JSONTokener.syntaxError(JSONTokener.java:450) at org.json.JSONTokener.nextValue(JSONTokener.java:97) at anywheresoftware.b4a.objects.collections.JSONParser.NextArray(JSONParser.java:60) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144) at anywheresoftware.b4a.BA$2.run(BA.java:370) at android.os.Handler.handleCallback(Handler.java:739) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:135) at android.app.ActivityThread.main(ActivityThread.java:5254) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:905) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:700)لینک ارسال
