دسترسی ران تایم در b4a 10.70
aaaaab
با سلام
در b4a نسخه 10.70 دسترسی های کتابخانه runtimepermissions را به برنامه اضاف می کنم از برنامه خارج می شود. از کتابخانه Dexter جهت گرفتن دسترسی ها استفاده می کنم با کتابخانه پوشه تداخل داره و خطای زیر را می دهد. لطفا راهنمایی کنید.
B4A Version: 10.70
Parsing code.    (0.04s)
    Java Version: 8
Building folders structure.    (2.70s)
Compiling code.    (0.18s)
Compiling layouts code.    (2.43s)
Organizing libraries.    (0.00s)
    (Android Support Library)
Compiling resources    (44.94s)
Linking resources    (15.34s)
Compiling generated Java code.    (24.20s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver$Stub;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver$Stub$Proxy;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver$MyResultReceiver;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver$MyRunnable;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/app/INotificationSideChannel;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/app/INotificationSideChannel$Stub;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692)
    at com.android.dx.command.dexer.Main.runMultiDex(Main.java:366)
    at com.android.dx.command.dexer.Main.runDx(Main.java:291)
    at com.android.dx.command.dexer.Main.main(Main.java:249)
    at com.android.dx.command.Main.main(Main.java:94)
Caused by: java.lang.InterruptedException: Too many errors
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684)
    ... 4 more
